Automation question - compile
"path1\\Igor.exe" /X "String fileN="path2\\file1.ipf";OpenProc fileN;Execute "Func1()";Quit/N"
In other words, I am just using /X (Execute) instead of /Automation.
This worked at least once, but my current problem is that I need to manually compile the procedure before I can call the function.
In other words, after the command starts and Igor and successfully reads the procedure file file1.ipf, the procedure window displays the Compile button and I have to manually do that before the function Func1() will run. I tried compiling the procedure and then saving it again, so that Igor would read a compiled version, but that isn't working. If I manually open file1.ipf, then it doesn't require compilation, only when I open it from this command line using OpenProc.
Tom
You need to look at Execute/P which has special keywords loading procedure files and causing Igor to do a compile. To learn more, copy this command and execute it on Igor's command line:
DisplayHelpTopic "Operation Queue"
You can also look at Igor's package loader procedure file which makes extensive use of Execute/P, though it does not do it via the Igor command line /X flag. Still, it will show you what Execute/P can do. First, execute this command:
SetIgorOption IndependentModuleDev=1
which will make the various independent modules visible. Then go to Windows->Procedure Windows->WMMenus.ipf.
You're talking about an advanced project here. Best of luck with it!
September 16, 2013 at 09:20 am - Permalink
thanks!! This works beautifully. I had actually read the manual on Execute/P but didn't follow the reference to the queues, thinking I didn't need them, and searching the manual for "compile" was too tedious. Also, once I put one command on the queue, I needed to put all of them on, so that they don't change order (Quit/N shouldn't run first). The script command now looks something like this (real names abbreviated):
Tom
September 17, 2013 at 01:03 am - Permalink
