BTW, a handy way to find such things is:
1. Choose Help->Search Igor Files.
2. Uncheck all checkboxes.
3. Check the "Help Files" and "Topics and Subtopics Only" checkboxes.
4. Check the "Igor Pro Folder" checkbox.
5. Enter "Packages" (without quotes) in the Search For edit box.
6. Click Search.
6. Click Search.
August 16, 2013 at 10:49 am - Permalink
is part of #include .
But then the help is not clear. It asks to write:
Execute/P/Q/Z "INSERTINCLUDE \"Sample Package\""
Execute/P/Q/Z "COMPILEPROCEDURES "
as part of running the package, but this does not work.
EDIT: I figured out that I can use this:
KBColorizeTraces#KBColorTablePopMenuProc("",0,"Rainbow")
It works, but gives an error "attempt to use a null string variable.
August 16, 2013 at 12:30 pm - Permalink
If you will provide a precise explanation of what happens I may be able to help.
August 16, 2013 at 03:14 pm - Permalink
I know it has been a couple of months already, but anyway...
It worked fine with this:
KBColorizeTraces( 0.5,1,0)
The command: KBColorizeTraces#KBColorTablePopMenuProc("",0,"Rainbow") does not work, but not an issue.
November 22, 2013 at 09:11 pm - Permalink
