Small bug in IGOR 6.32A
Hi!
I think I have found a small bug in IGOR 6.32A (I cannot check if this was already the case in the previous versions). In the "Add Annotation" window when adding a TextBox to a graph on the left hand side there is the pop-up menu "Special". Hoovering the mouse over any item of this menu gives a short description in the IGOR status bar. It seems that this information is missing for "Line Spacing", moreover in the status bar the help text is showing the info for "Superscript". Status bar info for any other pop-up menu item is then displayed for the next one, e.g. for "Backslash" it shows "Use after a subscript or superscript to return to the main line." (whereas this should be displayed while hoovering the mouse over "Normal").
EDIT: I am using IGOR 6.32A on Windows XP.
Can anyone confirm this?
Gregor
