Code for Standard Deviation, Averages and r statistic
GeraldJames
I have completed numerous experiments for analysis of H2O (water vapour mixing ratio) and D_DH (deuterium). For these experiments (often lasting in excess of 8 hours with 5 sec data points), I have performed variable temperature increases which are sometimes 40 mins, sometimes 60 mins, sometimes longer. These temperature increases cause differences in the data which I’m testing for to understand the effect of temperature on H2O and D_DH.
Currently I’m using WaveStats to generate the average and standard deviation over each temperature increase as well as the r statistic (StatsLinearCorrelationTest/T=1/Q H2O,D_DH). However, currently I’m doing this process manually, which is not only very time consuming, but can be prone to errors during data entry.
I’m wondering if anyone has an Idea to formulate a code with the input of a data point range which captures each temperature range corresponding to a time I have recorded for each temp setting (i.e. data points 122 – 350) that returns the standard deviation, average vale and ‘r’ statistic over the designated range of points. As well as this I would need to repeat this process multiple times for each temperature range in an experiment.
Any help would be greatly appreciated!
July 21, 2013 at 11:53 pm - Permalink
Here's my version that I end up using all too often. You'll need to modify this to meet your own needs (add a second raw data wave, add in the code to do StatsLinearCorrelationTest on subsets of the raw data, do anything else...?). I don't know if you started down the road of learning to write a function yet, but if not this will get you started:
July 22, 2013 at 08:32 am - Permalink
You need to set it up by creating two waves expStart and expStop which represent the start (non-inclusive) and stop (inclusive) times of each desired averaging period. e.g., if you did an experiment from 11:00 to 12:00 today:
will need to be done before running
averageExperiments(data, dataTimes, expStart, expStop)
.I'll leave the addition of the r-values code to you...
Note that using Extract means your times don't have to be ordered, but it makes the function way slower on large waves. The second helper function isn't really necessary but I had used it in my own function so I just threw it in here.
July 25, 2013 at 06:26 am - Permalink
how we can write a command for Date_time 1 hr average with other waves
July 13, 2018 at 11:49 am - Permalink
