matrix data sorting with many columns
I am wanting to sort a 2D wave with 900+ columns. I want to sort the matrix wave such that the rows are rearranged with all values of column 1, for example, in ascending order (similar to an Excel data sort). I've been doing some Google searching and reviewing priors posts on this forum. I can work with either a single 2D wave or 900+ 1D waves. I've got the 'matrix' data available in either format. The wave lengths are about 25e3 rows, just for reference.
I have reviewed this topic: Sorting two waves simultaneously, a la Excel
In my case, the example method from Howard would require listing the 900+ explicit 1D waves in the Sort command (or so it seems to me). I've messed around a bit with trying to sort the 2D wave directly, but thus far no luck.
Thanks. Josh
Joshua Lorenz
Kato Engineering
July 10, 2013 at 09:47 am - Permalink
One way of accomplishing what you want is to split your data into columns and then apply the Sort operation with a list of wave names corresponding to the columns. The difficulty here is that with 900 columns you will quickly exceed the maximum length of the command line. The solution is then to run multiple Sort operations, say in groups of 50 columns or so, always providing a copy of the unsorted column 1 as the key wave.
July 10, 2013 at 04:39 pm - Permalink
MakeIndex key, valindx
does the same thing as MDSort's
, and
IndexSort valindex, wavetobesorted
is equivalent to
except I think it does the sorting in place (Igor doesn't need to make a complete copy of the unsorted wave the way the second form does). It would be nice to have MD aware IndexSort precisely for large MD waves, but copy and assign works. Finally, I don't see why MDSort needs the for loop:
should do the same thing as explicitly stepping through rows with the for loop and the ii variable.
July 10, 2013 at 01:52 pm - Permalink
http://www.igorexchange.com/node/599
July 10, 2013 at 04:37 pm - Permalink
July 10, 2013 at 05:26 pm - Permalink
