Help with mouse-to-image user function/marquee menu customization
daggaz
Looking through the manual, I see that I can use the marquee menu as an input device. This seems like the obvious place to start, but is it possible to change the mouse functionality, such that instead of having the default draggable ROI function, a control button could be used to change this to a simple line, or single pixel, etc..
Ultimately, I'd like to build some of my own tools, so that I can do some of the basic functions of Fiji inside of an Igor environment.
There are probably better examples, but one I have used to get tips for doing this sort of thing is the Graph Magnifier. Add the following line to your Procedure window to get it:
Have a browse through the various image processing utilities to see if anything else helps.
July 10, 2013 at 04:32 am - Permalink
Two related things I would like to see in Igor are a magnifier and a 'hand' tool in the tool palette, for rapidly zooming and moving around on graphs. What other improvements do you think would make Igor more useful in Fiji/ImageJ-like image processing?
July 10, 2013 at 05:34 am - Permalink
As far as Fiji-type tools, I think just the general toolbar is a must-have, and their image processing menus are much more fleshed out than Igor's. But while Fiji's GUI is superb for human interaction with a single image, it is a very tedious process to do anything with the resultant data. The copy-paste clip board when you take a line integral is a nightmare for example.
A sweet mix would be to just tie the whole toolbar into Igor, with the same command line print which is so great when you want to code something without having to read 3 chapters of the user manual. Do it once with point and click, get the commands from the command line, adapt to code. Whoever put that concept into Igor deserves a bonus.
July 11, 2013 at 01:06 am - Permalink
