elicit user input to define save path
I would like to make the function below save all waves to a path I define without asking each time for the folder for each wave.
Thanks for your time.
Function SaveWavesFromCurrentDF(matchStr)
String matchStr
    String list
    list = Wavelist(matchstr,";","")
    NewPath/O pathUserSelected, "C:Users"
    Save/O/C/W/I/B /P= pathUserSelected list
The /I flag tells Save to display a dialog so remove that.
Set the path to a folder for which you have write access. In my case "C:Users:Howard" works.
I don't want to remove the dialog box because I would like the user to choose where to save the waves. When I remove the I/ flag then the save location has to be prespecified in the script which I don't want, because it will change.
I think what you are saying is that you want the user to choose the folder once and save all of the waves there. If that is the case then do this:
    String matchStr
    String list
    Variable numWaves = ItemsInList(list)
    if (numWaves == 0)
        Print "No waves matched"
        return -1
    NewPath /O pathUserSelected         // Let the user choose the path
    if (V_flag != 0)
        Print "Cancelled"
        return -1               // User cancelled
    Save/O/C/W/B /P=pathUserSelected list
    Printf "%d waves saved\r", numWaves
    return 0        // Success
