keeping the x axis at the same length
I am plotting some data and saving the plot in tiff files.
The physical length of the x-axis changes, examples: when A) the y-axis goes from 0 to 4 with unit steps, the x-axis is shorter than B) when the y-axis goes from -1 to 4 with unit steps. This because the text "-0.1", with its minus sign, is longer than "0.1". This is annoying if you have to put A and B on top of each other. How to fix the length of one axis?
Thanks
Make ddd = p - 50
SetScale/P x, -50, 1, ddd
//PLOT A
display/W=(10,0,529,433) ddd[50,54]
SavePICT/O/E=-7/B=72/P=igorr as "aaa3.tif"
//PLOT B
display/W=(10,0,529,433) ddd[49,54]
SavePICT/O/E=-7/B=72/P=igorr as "aaa2.tif"
June 28, 2013 at 07:02 am - Permalink
SOLVED
June 28, 2013 at 09:14 am - Permalink
ModifyGraph margin(left)=50
before saving each graph.June 28, 2013 at 09:22 am - Permalink
