Find Levels
Quick question,
I'm trying to implement the FindLevels function for a list of 30 data points, and I'm doing it so using a for loop. It basically goes through each point in the list, and sees how many times level crossings occur, but every time I open the designated wave to find the locations where the level crossings occur, I don't get the right numbers. Here is a code snippet:
        Wave rawwave1 //The data
    Variable count0 = 0
    Variable numPoints = numpnts(rawwave1)
    Variable i
    for(i=0; i<numPoints; i+=1)
        FindLevels /D=SelectiveCrossings/EDGE=0/R=(0,29) rawwave1, rawwave1[i]
            count0 += 1
Your example code doesn't make any sense.
Try describing the problem more clearly. What do you want to do? Add an example analysis (not example code - a few numbers of input and the output that you would like to see).
Since you are overwriting your destination wave during each iteration of the for loop, it will only have the results for the last FindLevels operation.
Additionally, the output is the x level where it is crossed, not the point number, so wave scaling must be considered. As a quick example, consider the following numbers: 10,5,5,0. Where does it cross 5? points 1 and 2 (if you have wave scaling, the results could read as 10,20 or 0.0003,0.0006. Get my point?)
Finally, your count variable will end up being i after the for loop. What is the point of this?
Hi proland, thank you very much your reply. I did realize what you came to say after going through my code snippet again. The project I'm working involves going through a a large number of data sets and basically calculating this delta kronecker function type computation. In order to do this, the code snippet I had posted above was an integral part to sort through the data.
I basically have a bunch of waves with the following data,
XValues YValues
For example, the waves have been compiled into one table in the following manner.
XValue = 4, Yvalue = 1
Xvalue = 10, Yvalue = 1
Like you had mentioned, the destination wave is being overwritten in each iteration of the loop. I've modified my code to go for point numbers, though you have a great point in wave scaling. I will look into that too.
My only problem is basically on how I could deal with the overwriting of the destination in each iteration. In this phase of my project, for each number in the Yvalue wave, I have to find out the number of level crossings, where that particular number is crossed, as well as the different locations. And I have to do this for all points throughout the wave.
I thought for loop would help for this, but that does lead to the overwriting. I would be very grateful for suggestions, as I'm only a beginner in Igor.
I don't understand what you are trying to do but . . .
SelectiveCrossings is an output from a given iteration of the loop. You need another output wave to which you concatenate results from each loop iteration - or something like that.
You can use the Concatenate/NP operation to concatenate SelectiveCrossings onto the real output wave.
As Howard mentioned, you need a different destination wave. Try this ...
make/O/N=0 AllCrossings
for ...
   FindLevels /D=SelectiveCrossings ...
   Concatenate/NP=0 SelectiveCrossings AllCrossings
   count0 += 1
