Problem with quicktime movie cropping data graphs
daggaz
I have changed my monitor display settings, changed the window size in the view menu inside quicktime, and I even went into the code and increased the height of the graph being cropped. The final solution just made the movie window taller, but it still crops.
Is this a known problem or is there a specific command I can try searching for or implementing in order to fix it? Sorry I cant be more specific, the code is rather extensive and confusing.
The function which is specifically creating the movie is this one:
function trajectoriesMovieSing( inputTRace, fileName , partInfo, addInfoW ) wave inputTRace, partInfo, addInfoW string fileName // variable loopVar = 0 // make/o/n = ( dimSIze( inputTRace, 0 )) crop1, crop2, crop3 // show the graph dowindow/k graph1 display/n=graph1 /hide = 1 crop1 appendtograph/w = graph1 /l=left1 crop2 appendtograph/w = graph1 /l=left2 crop3 // adjust axes ModifyGraph /w = graph1 grid(left)=1,grid(left1)=1,grid(left2)=1,axisEnab(left)={0,0.32}; ModifyGraph /w = graph1 axisEnab(left1)={0.33,0.65},axisEnab(left2)={0.66,0.98}; ModifyGraph /w = graph1 freePos(left1)={0,bottom},freePos(left2)={0,bottom} ModifyGraph /w = graph1 gridRGB(left)=(0,0,0),gridRGB(left1)=(0,0,0),gridRGB(left2)=(0,0,0) modifyGRaph/w= graph1 width=900,height=900, fSize=12 // CHANGING THE HEIGHT VALUE ABOVE DOES NOT FIX THE PROBLEM// // Label/w= graph1 left "intensity (a.u.)"; Label/w= graph1 bottom "time (s)" wavestats/q inputTRace SetAxis/w = graph1 left V_min,V_max SetAxis/w = graph1 left1 V_min,V_max SetAxis/w = graph1 left2 V_min,V_max // newMovie/P = Path4/F = 60/Z as fileName // do crop1[ ] = inputTRace[ p ][ loopVar ] crop2[ ] = inputTRace[ p ][ loopVar + 1 ] crop3[ ] = inputTRace[ p ][ loopVar + 2 ] // adjust axis wavestats/q crop1 SetAxis/w = graph1 left V_min,V_max // wavestats/q crop2 SetAxis/w = graph1 left1 V_min,V_max // wavestats/q crop3 SetAxis/w = graph1 left2 V_min,V_max // textBox/w= graph1/n =text1/k textBox/w = graph1/n = text1/a = MT /f = 0 /E "# : "+num2str( loopVar )+" xC: "+num2str( partInfo[ loopVar ][ %xCP ] )+" yC: "+num2str( partInfo[ loopVar ][ %yCP ] )+" z0: "+num2str( addInfoW[ loopVar ] ) AppendText /W = graph1 /N = text1 "# : "+num2str( loopVar + 1 )+" xC: "+num2str( partInfo[ loopVar + 1 ][ %xCP ] )+" yC: "+num2str( partInfo[ loopVar + 1 ][ %yCP ] )+" z0: "+num2str( addInfoW[ loopVar + 1 ] ) AppendText /W = graph1 /N = text1 "# : "+num2str( loopVar + 2 )+" xC: "+num2str( partInfo[ loopVar + 2 ][ %xCP ] )+" yC: "+num2str( partInfo[ loopVar + 2 ][ %yCP ] )+" z0: "+num2str( addInfoW[ loopVar + 2 ] ) // doUpdate // addMovieFrame // loopVAr += 3 if( loopVAr + 2 >= dimSIze( inputTRace, 1 ) ) break endIf // while( 1 ) // closeMovie doWindow/k graph1 // end
Also, how do you do spoiler tags on this board? Tried to hide that code but hide and spoiler dont seem to work inside the tag symbols.
EDIT: After googling a bit, seems cropping is a problem with the latest quicktime version, so I tried downgrading to QT-7 which was the latest supposedly stable version without the trouble. It didnt fix the problem, so I cant blame crApple just yet..
June 10, 2013 at 05:33 am - Permalink
