Monte Carlo Error Analysis with Motofit
iherrera
http://www.igorexchange.com/node/2330
However, I have not been able to obtain meaningful results with the Moto_montecarlo function in the the latest release of the motofit v4 package (http://sourceforge.net/projects/motofit/files/motofit/ ). The matrix generated contains the same values for all the rows. These values are the same a the intial guess values. The command that I used is
Moto_Montecarlo ("myfitfunc", param_w, yy_w, xx_w, err_w, "holdstring", iter)
I also tried using a more recent version of the installer ( http://sourceforge.net/p/motofit/svn/775/tree/trunk/installers/), but Igor cannot find the definition for "sockitwavetostring."
I have two questions:
Has anyone tried using the Monte Carlo analysis in motofit with a user generated generated function?
Is there another version of motofit that I can use to run the Monte Carlo analysis? Ideally, I would like to use a version that runs multiple threads to speed up the process
Thanks
Could you post a packed experiment file that demonstrates what you are trying to do?
Can you download and install the latest version and let me know if you still have problems?
https://sourceforge.net/projects/motofit/files/latest/download
I have just downloaded this and have checked that the code compiles. I also used this version to do a Monte Carlo analysis.
I remember fixing some issues along this line, when I was created code that could fit in parallel.
March 20, 2013 at 01:18 pm - Permalink
I'll pack an experiment with a simple example of what I am trying to do. In the mean time, I tried installing the latest version of motofit and I got three errors after executing the motofitInstaller.exe and restarting Igor. It seems I am missing a few XOP libraries.
First, I get a popup window saying "XOP dynamic link failed." Then, I get a compilation error for
sockitwavetostring
. I commented the lines with the previous command. Finally, I got a compilation error for "easyhttp" which I also commented.The previous errors disappear after running platypusInstaller.exe but I get two additional compilation errors.
1) A couple of commas were missing in the following line of Pla.reductionPOD.ipf
2) a missing wave reference in Pla_Xrayreduction.ipf
Thanks for the help
March 20, 2013 at 05:21 pm - Permalink
When you get the message "xop dynamic link failed" does Igor give anymore information? I want to know which xop is failing to load.
It's probably better to email me directly.
March 20, 2013 at 06:56 pm - Permalink
Just Motofit, you don't need to install platypusInstaller.exe
March 20, 2013 at 08:10 pm - Permalink
March 21, 2013 at 12:51 pm - Permalink
