Image Particle Analysis ellipse value reporting
I am using the Image Particle Analysis and it is working very well.
I would like to have access to the major and minor axis that are presumably produced from the "Ellipses" option.
Is this readily accessible in some way?
I am assuming that you are using the Particle Analysis panel which somewhat obscures the underlying operation. Particle analysis is performed by the ImageAnalyzeParticles operation. When you invoke the operation with the /E flag you get the M_Moments wave which contains the information you want. To find out more execute:
DisplayHelpTopic "ImageAnalyzeParticles"
and look for the paragraph for /E.
