Iterative FitFunction parameters
I'm fitting a lot of peaks in my data and am trying to write a somewhat efficient function to fit the peaks that I define and generate waves with the results of each fit (to include the coefficients, errors, and chi-squared information) so that I can display them in a table. My function also generates a tag which is anchored to each fitted peak containing information from the fit.
The issue that I'm running into as I continue to try and optimize it even more, is being able to define my coefficients and fit-parameters. What I would like to do is create a table which has my coefficient guesses and fit parameters for each peak I want to fit, as separate waves. By fit parameters, I simply mean Xstart and Xfinish for my Gaussian fit.
My code, which currently works with the values preset in the function, is below, followed by what I would like to try and impliment.
Function TestMultiFit2(coef,sigma,chisq,Npnts,n) String coef String sigma String chisq String Npnts Variable n Variable i Variable V_chisq Variable V_npnts Wave W_Sigma Wave W_Coef Wave wave_0 String i_string String CoefString String SigmaString String ChisqString String NpntsString For (i=0;i<n;i+=1) //Convert i to a string sprintf i_string, "%d", i //Make n user-defined waves with sequential names_i CoefString = coef + "_" + i_string Make/D/N=5/O $CoefString Wave coef_i = $CoefString // Fit Peak i coef_i[0] = {-10,10000,178000,250,1} FuncFit/NTHR=0 SingleGauss coef_i watch_kev_Hist[573,623] /W=weight_kev_watch /I=1 /D // Make Sigma Wave SigmaString = sigma + "_" + i_string Make/D/N=5/O $SigmaString Wave sigma_i = $SigmaString sigma_i = W_sigma // Make Chi-Squared Wave ChisqString = chisq + "_" + i_string Make/D/N=1/O $ChisqString Wave chisq_i = $ChisqString chisq_i = V_chisq // Make "Chi-Squared Number of Data Points" Wave NpntsString = Npnts + "_" + i_string Make/D/N=1/O $NpntsString Wave Npnts_i = $NpntsString Npnts_i = V_npnts // Create a Tag with relevant information anchored on the Centroid Peak value String Peak sprintf Peak, "Peak " + i_string+"\rE=%g keV", Coef_i(3) Tag/C/N=Fit1Results/X=10/Y=10 watch_kev_hist,Coef_i(3), Peak EndFor End
If I want to fit 3 specific peaks, I would have a wave for each peak in a table, ordered in such a manner as I can sift out whatever value I need for each coefficient guess and Xstart/Xfinish.
Peak_0
w_0
w_1
w_2
etc
Peak_1
w_0
w_1
w_2
etc
But when I try to incorporate such a method in my function, it messes up all of the following parts of the function which use the "i" value. Below is a similar idea to the modification I made to my function in an attempt to accomplish that:
// Fit Peak i coef_i[0] = {Peak_i(0),Peak_i(1),Peak_i(2),Peak_i(3),Peak_i(4)} FuncFit/NTHR=0 SingleGauss coef_i watch_kev_Hist[Peak_i(5),Peak_i(6)] /W=weight_kev_watch /I=1 /D
where Peak_i refers to waves I've created in a table which hold all those values.
To sum up, I'd like my function to fit Peak 1 with my defined guesses and Xstart/Xfinish, generate waves containing the results of the fit, and run back through to fit Peak 2 with the defined guesses for Peak 2, all the way through n peaks that I define. It currently does everything, except iterate the coefficient guesses and Xstart/Xfinish values.
I appreciate any input on the issue I'm running into with using an "i" value in the Fit Function parameters, and possible solutions. I'll be continuing to try to figure it out over the weekend.
Thanks.
For details execute:
March 10, 2013 at 10:48 am - Permalink
You're absolutely right. I was attempting to keep my post to a minimum to explain what I did with a simple example of what sort of edit to the fit function itself I was doing. I was creating a Peak_i wave reference (which I didn't show), but my problem was in how I defined my string name for it, which I see now from your example. I was defining the Wave Peak in a function parameter, and then using Wave Peak_i = Peak. As well as a few other attempts, which were all wrong. I'll be more explicit next time in the explanation of my full attempt(s).
Thanks for the clarification! The code now works just fine with an edit to the Fit Function section, as well as the Tag generator section so that it doesn't erase over the same tag with each iteration:
I have a separate function to create the peak waves and generate the table with each one for parameter entry. Thanks for your help.
March 10, 2013 at 12:54 pm - Permalink
