procedure to generate a wave that would be the mean of several waves
daviddoji
If I want to make the average of these waves, I have to type in a console:
duplicate 0__temp, ave__temp
ave__temp = (0__temp+1__temp+...)/"number_of_waves"
I would like to make a procedure to do this more automatically and not to type every time these lines. It should be a smart way to do it.
Thanks in advance
February 27, 2013 at 09:00 am - Permalink
But if I want to call the procedure for example like this:
average(temp)
I would need that the procedure take all the wave ending with "temp" and make the average. should it be valid this procedure to do it?
Wave WaveList(*_waves_to_average)
string name_of_wave = nameofwave(waves_to_average)
do
fWaveAverage(WaveList("*_waves_to_average", ";", ""), 0, 3, "$name_of_wave_ave", "")
Thanks in advance
February 27, 2013 at 10:51 am - Permalink
At the prompt, the "Include NAN points" option will average waves even if some are missing intermediary values (ie, those set to NAN). The "Generate error wave" option computes the standard error on a per point basis for the population of waves. The function will by default move the selected source waves to a folder called "Averaged", or you can use the drop-down menu to leave them alone, delete the source waves, or move them to a custom folder name specified in the "Custom Folder" field.
string selected=SelectedWaveList()
if(itemsinlist(selected)>1)
variable option=3
variable truncate=2
variable generr=1
string newFolder
string keystr=getdatafolder(1)[0,strlen(getdatafolder(1))-1]
string name="waveAverage"
prompt option, "Manage source waves:", popup, "Do nothing;Delete waves;Move waves to \"Averaged\" folder;Move waves to custom folder..."
prompt newFolder, "Custom Folder:"
prompt name, "Base name for average wave"
prompt truncate, "Include NAN points?",popup,"yes;no"
prompt generr, "Generate error wave?",popup,"yes;no"
DoPrompt "Average Waves", name, option,newFolder,truncate,generr
if(!V_Flag && itemsinlist(selected)>1)
string avgName=UniqueName(name,1,0)
make/n=(numpnts($stringfromlist(0,selected))) $avgName=0
make/o/n=0 indexnans
WAVE indexnans=$nameofwave(indexnans)
WAVE avg=$avgName
SetScale/P x 0,deltax($stringfromlist(0,selected)), stringbykey("XUNITS",waveinfo($stringfromlist(0,selected),0)), avg
variable i,j
string avgnote
Print "Waves averaged:"
for(i=0;i<itemsinlist(selected);i+=1)
WAVE wavenm=$stringfromlist(i,selected)
if(truncate==1)
for(j=0;j<numpnts(wavenm);j+=1)
FindValue/V=(j) indexnans
if(numtype(wavenm[j])==2 && V_value==-1)
insertpoints 0,1,indexnans
indexnans[0]=j
avg+=wavenm
print " "+nameofwave(wavenm)
//manage options
if(option==2)
killwaves/z wavenm
if(option==3)
newdatafolder/o Averaged
//execute "ModifyBrowser expand="+num2str(GetBrowserLine(":Averaged:"))
MoveWave wavenm, :Averaged:
avg/=itemsinlist(selected)
//generate std err wave here
if(generr==1)
make/n=(numpnts($stringfromlist(0,selected))) $(avgName+"_err")=0
wave err=$(avgName+"_err")
//perform error for full wave
err+=(wavenm-avg)^2
err=sqrt(err/(itemsinlist(selected)))/sqrt(itemsinlist(selected)-1)
if(truncate==1)
variable numnans
for(i=0;i<numpnts(indexnans);i+=1)
numnans=0
avg[indexnans[i]]=0
for(j=0;j<itemsinlist(selected);j+=1)
WAVE wavenm=$stringfromlist(j,selected)
if(numtype(wavenm[indexnans[i]])==0)
numnans+=1
avg[indexnans[i]]+=wavenm[indexnans[i]]
avg[indexnans[i]]/=numnans
//perform per-point error for index wave
if(generr==1)
//zero error point
err[indexnans[i]]=0
numnans+=1
err[indexnans[i]]+=(wavenm[indexnans[i]]-avg[indexnans[i]])^2
err[indexnans[i]]=sqrt(err[indexnans[i]]/numnans)/sqrt(numnans-1)
killwaves indexnans
Print "Average wave: "+nameofwave(avg)
Abort "Select more than one wave to average."
Function/S SelectedWaveList() //all selected waves...
string SelectedWaves=""
variable i
do
if(waveexists($(GetBrowserSelection(i))))
SelectedWaves+=GetBrowserSelection(i)+";"
i+=1
while(strlen(GetBrowserSelection(i))>0)
return SelectedWaves
February 27, 2013 at 01:51 pm - Permalink
Function averageTempWaves(NameforNewWave)
String NameforNewWave
String listofwaves = WaveList("*temp", ";", "")
fWaveAverage(listofwaves, "", 3, 1, NameforNewWave, NameforNewWave+"_STE")
WaveList is a function that returns a string containing a semicolon-separated list of waves that match the input criteria. The way I have written it, it lists all waves whose names end in "temp", it puts a semicolon between names, and it doesn't apply any WaveList options (that's the final empty quotes). The function takes a string as input that is used to name the output waves. It creates an average wave and a standard error wave that has the same name with "_STE" appended to the name.
If you have waves data1, data2, data3, data1temp, data2temp, and data3temp, it will list average the last three of those waves. You might invoke it like this:
averageTempWaves("myAverage")
The output will be two waves: myAverage containing the averages, and myAverage_STE containing the standard error. Of course, three inputs isn't enough to make the standard error meaningful, but you get the idea.
Or you can use the Wave Average control panel as a GUI, select by Name in the top menu, and enter "*temp" in the Name Template box.
There is a demo experiment about this package: File->Example Experiments->Ave, Box Plot, Percentile.
February 27, 2013 at 03:42 pm - Permalink
