Pop up menu
I wanted to make a procedure of mine more interactive. So to do that I thought that I could create a Menu that when selected will pop up a window that will allow me to enter the parameters of my function.
I noticed that to create the menu I should use the Menu function:
Menu "Test"
"Function", /Q, my_function()
But how can I get the pop up window and fill in the function parameters? Instead of calling my function in the command window and filling up all parameters separated by commas I would like to have a window similar to the one in "Curve Fitting" on which in can fill the guesses and etc
Thanks in advance,
Gabriel
February 5, 2013 at 02:35 pm - Permalink
February 5, 2013 at 02:37 pm - Permalink
After selecting the waves with a pop up I get a string with the wave name but not the wave it self. How can I have the wave in my procedure? I tried using TraceNameToRef but didnt get it working.
And one more question, is it possible to have in the pop up menu, while entering the parameters, the last inputed values instead of zeros?
Thanks
February 6, 2013 at 11:00 am - Permalink
If sWaveName is a string variable from your prompt code with the name of the wave, then
Wave w = $sWaveName
will give you a local reference (w) that you can use to access that wave.
Copy DisplayHelpTopic "Wave References" to the command line to learn more.
February 6, 2013 at 11:41 am - Permalink
Here's the piece of the code, can someone point to me what I'm doing wrong?
I can see with debugger that the string test has the right wave name associated but I can't get the contents of that wave to my "u" wave. I get the following error :
"While executing a wave read, the following error occurred: Attempt to operate on a null (missing) wave."
Thanks
February 6, 2013 at 03:27 pm - Permalink
If it starts with a number, or contains a space, the wavename will need single quotes around it. A not-so-obvious error made even more annoying in that some functions require the single quotes while others do not. Using the contents of the string Test, can you do wave commands (using exactly what test contains)?
February 6, 2013 at 04:41 pm - Permalink
In the debugger, under the tab "WAVEs and STRUCTs" the wave u is displayed as "u < null >". So I guess that I can't do any wave related commands.
I have a string with the wave name and I would like to use it to initialize the corresponding wave in my procedure. How can I do that?
February 7, 2013 at 04:18 am - Permalink
This is the output from the history window after running the function and selecting w1_test.
You might give this a try, if it works, then the problem may lie in the file name. By the way, your code doesn't change the data folder between the Prompt and the assignment of the wave, does it? Wavelist only acts on the current directory and doesn't give the full path to the waves that it finds.
February 7, 2013 at 05:42 am - Permalink
Yes it did change, I'm very sorry that I didn't mention that earlier. Without the directory change all works fine. Thank you very much jtigor.
However, I wanted to have the waves that I crate with this procedure in directory of their own. Should I create a directory in the end of the procedure and than move the waves? How can I finish with the waves in their own directory?
Thank you all for your patience.
February 7, 2013 at 06:52 am - Permalink
It's a little hard to tell how to go about this without more details.
Once you create the wave reference it will be absolute; you can create a new directory and make it the current directory without affecting the wave reference. It's just that when creating a reference with "WAVE w = $wavename" Igor will look for the wave in the current directory if "wavename" does not include path information.
So, going on what you have said so far, I can suggest that you create the wave references before creating or changing directories, then you should be ok.
February 7, 2013 at 08:07 am - Permalink
I guess that the easiest for me would be just to use the
MoveWave
to get the waves into the data folder.So what I did was this:
Where u is the wave I referenced before and round is a variable created before. But I get the following error: "While executing MoveWwave, the following error occured: name already exists as a wave"
February 7, 2013 at 02:55 pm - Permalink
Unfortunately, NewDataFolder/O does not delete the waves in the currently existing data folder and MoveWave does not have an overwrite option (kinda wish it did). I would do this like so...
This is a little different but it's just because I tend to set the new folder as active so moving waves is a little easier.
February 8, 2013 at 05:40 am - Permalink
In your code
movewave u, dfr:$folder
$folder is interpreted as the new file name, not a folder name. So your starting wave is moved to the data folder referenced by dfr but the name is changed to the contents of $folder.
To get the behavior that I think you want, you could modify your code by creating a second datafolder reference that includes $folder. (I've included an entire procedure for easier testing, but see the part at the end.)
By the way, I changed the white space in your new folder name to underscores. I tested the code both with white space and underscores and it works as expected in each case. However, I prefer I life without the heartaches that such blanks can cause.
February 8, 2013 at 05:47 am - Permalink
Everything is working as expected now, thanks again.
February 8, 2013 at 07:21 am - Permalink
As an aside, it is worth mentioning that in the particular case used here, the single quotes are not only not needed, but are actually not tolerated. When you use
Wave w = $mystringvariable
the entire contents of mystringvariable are taken as the wave name, and the single quotes cannot be present. The single quotes are necessary on the command line or any place where Igor needs them for parsing a string.
OK- that last gets you to a gotcha- if you include a *path* in a string variable, then you need single quotes around any liberal names in the path:
February 8, 2013 at 04:23 pm - Permalink
I was still working on the pop up window and I wanted to have a list of all folders and subfolders to choose from. I've put together a command,
ReplaceString(",",StringByKey("FOLDERS",DataFolderDir(1)),";")
, that when runned from root it returns me all the data folders but I can't choose the subfolders. How can I do that?This would be integrated in a prompt enviroment as:
February 10, 2013 at 11:20 am - Permalink
If you create a control panel, you can use the Wave Selector Widget to provide wave and data folder selections in your panel. It is implemented as a WaveMetrics procedure. To learn more about it, see the demo experiment: File->Example Experiments->Programming->WaveSelectorWidgetExample.
February 11, 2013 at 11:23 am - Permalink
It can be done by adding buttons to the data browser via
ModifyBrowser
which executes a function on every selected wave, or via a menu entry +GetBrowserSelection
to extract the selected elements. John's suggestion may be the best solution, but is also not all too easy to implement.February 12, 2013 at 05:43 am - Permalink
