Which screen is Igor on with multiple screens (Windows)?
I am running Igor on Windows, and am trying to control the position of a new floating panel based on the current location of the Igor application window.
I can get and use the system variables V_left, V_top, V_right and V_bottom using:
GetWindow kwFrameOuter, wsizeDC NewPanel/FLT/W=(V_left + 50, V_top + 50, V_left + 250, V_top + 150)
which works fine provided the application is not maximised on the screen, whereby the system variables all get assigned values of 2. In this case I can get the screen size using IgorInfo(0).
However, I can/am using multiple monitors...
I can detect how many screens are in use from:
Variable vNumScreens=NumberByKey("NSCREENS", IgorInfo(0))
and I can find the size of each screen from the "SCREENx" items returned from IgorInfo(0), but if the application is maximised I cannot find a way of determining which screen the igor application is maximised on.
Any ideas please?
Thank you,
Kurt
January 25, 2013 at 02:48 pm - Permalink
