Aliases
Henry S.
Is there a simple method for creating aliases for operations and functions?
For example, instead of:
appendtograph y2 vs x2
I would like to be able to do:
a2g y2 vs x2
Or, perhaps:
a2t
instead of appendtotable</copy>
or:
<code>mkdir
or md
instead of newdatafolder
There are workarounds using functions and macros, but options and arguments would have to be parsed and handled on a command by command basis.
Henry
No, this feature does not exist.
January 24, 2013 at 04:33 pm - Permalink
I am heartened that I got a response in less than half an hour. Thanks, hrodstein!
January 24, 2013 at 05:07 pm - Permalink
If you really wanted this, you could probably write your own external operations in an XOP that had shorter names but a similar syntax to the built-in operations, but I suspect you could find better uses for your time :)
January 24, 2013 at 06:45 pm - Permalink
And I knew that someone would bring up XOPs! It's a line that I'm not yet prepared to cross!
January 24, 2013 at 09:00 pm - Permalink
You show great wisdom!
January 25, 2013 at 09:16 am - Permalink
