Does anyone know a hook or other method to use for triggering a function upon offsetting a trace? I'd like to be able to drag a trace in a graph window to a new location (ie, for offsetting a threshold trace), and then when released have igor execute a function to take into account the new offset location, etc.
Caveat: The hook is not called if the trace offsets are set by a command, only if set by dragging.
Function GetTraceOffset(graphNameStr, traceIndex, xOffset, yOffset)String graphNameStr
Variable traceIndex // 0 for first trace, 1 for second, . . .
Variable& xOffset // Output
Variable& yOffset // Output
xOffset = NaN
yOffset = NaNString info = TraceInfo(graphNameStr, "", traceIndex)if(strlen(info) == 0)return -1endif// Strip out everything before "offset(x)" - (would not be necessary if I knew what I was doing with regular expressions)Variable pos = strsearch(info, "offset(x)", 0)Variable len = strlen(info)
info = info[pos,len]// Strip out everything after next semicolon - (would not be necessary if I knew what I was doing with regular expressions)
pos = strsearch(info, ";", 0)
info = info[0, pos]// Extract x and y offsets as stringsString regExp = ".*offset\\(x\\)={([^,]*),([^\\}]*)"String xOffsetStr, yOffsetStr
SplitString/E=regExp info, xOffsetStr, yOffsetStr
// Convert to numbers and return via pass-by-reference parameters
xOffset = str2num(xOffsetStr)
yOffset = str2num(yOffsetStr)return0EndFunction MyWinHook(s)STRUCT WMWinHookStruct &sVariable xOffset, yOffset
Variable rval= 0switch(s.eventCode)case4: // Mouse down
GetTraceOffset(s.winName, 0, xOffset, yOffset)// 0 means first trace// Printf "xOffset=%g, yOffset=%g\r", xOffset, yOffsetVariable/G root:gLastXOffset = xOffset
Variable/G root:gLastYOffset = yOffset
breakcase5: // Mouse up
GetTraceOffset(s.winName, 0, xOffset, yOffset)// 0 means first trace// Printf "xOffset=%g, yOffset=%g\r", xOffset, yOffsetNVAR lastXOffset = root:gLastXOffset
if(xOffset != lastXOffset)Printf"New X offset = %d\r", xOffset
endifNVAR lastYOffset = root:gLastYOffset
if(yOffset != lastYOffset)Printf"New Y offset = %d\r", yOffset
endifbreakendswitchreturn rval
EndFunction DemoSetCursorHook()Make/O jack=xDisplay jack
SetWindow kwTopWin,hook(testhook)= MyWinHook
For details on window hooks:
DisplayHelpTopic"Window Hook Functions"
Another approach would be to use a background task to look at the trace offsets periodically.
Another possibility is to run your function when the "modified" event for the graph is sent:
eventCode=8
eventName="modified"
A modification to the window has been made. This is sent to graph and notebook windows only. It is an error to try to kill a notebook window from the window hook during the modified event.
NOTE: If your function modifies the graph, add recursion protection to prevent responding to the resulting "modified" event again.
Great! I've used various Igor hook functions before, but missed the method for applying one to windows. I've got it set up and am exploring the various event triggers in the structure that might be beneficial. Thanks!
January 5, 2013 at 09:42 pm - Permalink
eventCode=8
January 6, 2013 at 10:16 am - Permalink
January 6, 2013 at 05:42 pm - Permalink
