Quirkiness with ModifyGraph
daggaz
string w_name = "awesome_wave"
make/o/d/n=10 $w_name
wave w = $w_name
w = (insert whatever data function here)
display w
modifygraph rgb(w)=(0,0,0)
but changing the modify line to this does:
modifygraph rgb($w_name) = (0,0,0)
Am I doing something wrong or is that working as intended? Thought my proxy wave handle "w" should work in all sorts of assignments.
The error in the first example comes from the fact that there is not trace named 'w' on the graph.
Note, that your 'fix' is not foolproof, as providing the wave name may be coincidental with the trace name, but not necessary always so (e.g., when a wave is appended twice). You may want to actually grasp the trace name directly from the graph (e.g., via TraceNameList).
December 21, 2012 at 05:36 am - Permalink
December 21, 2012 at 12:13 pm - Permalink
