Tab in a string wave
I'm trying to create a text file with the following display:
dat.001 (no TAB)
1,IRERUN (TAB)
dat.002 (no TAB)
1,IRERUN (TAB)
etc...
My issue is when I use "1, IRERUN (TAB)", it displays "1,IRERUN /t" instead.
I tried a few things such as "1, IRERUN: \r\(TAB)" but it did not work either, it displayed "1, IRERUN: \r\\t" instead.
Here is the code.
... make/T/N = (j*2) sWave variable jjs variable titi=1 for(jjs=0;jjs<(j*2);jjs+=2) String wname //= "dat."+ num2str(titi) Sprintf wname,"dat.%03d", titi sWave[jjs] = wname sWave[jjs+1] = "1,IRERUN " titi +=1 Save/P=$pathName /J /O/M="\r\n" sWave as "BATCHLIST.dat" // Delete "/P=$pathName" if you want to specify the path yourself killwaves/A return fileNameList ... Thanks!
To produce a tab character in a literal string use backslash followed by t. For example:
Here backslash t is an escape sequence that represents a tab character. This is more clear than using a literal tab character since an actual tab is not visually distinct from a space or multiple spaces.
For more information execute:
December 5, 2012 at 09:15 pm - Permalink
