image display question
s.r.chinn
modifyimage mask imcmplxmode=3
there are artifacts even when the magnitude of the wave is strictly zero. The strictly-zero part of most of the wave content has been verified by using the (magnitude) image cursor, by editing the wave, and by printing to the command line. I am attaching the .ibw wave file. Should I not expect that uniform zero regions show flat (if not 0) phase? I'm using IP 6.23, Windows 7.
I think the answer is here:
The image display mode is not doing anything that MatrixOP is not computing. So take it one more step and execute:
October 17, 2012 at 01:33 pm - Permalink
Thanks for your suggestions.
It turns out that the culprit lay in the way that the complex zero values were set in my 2D wave definition, using a logical multiplier factor whose value was 0 in certain regions. The resulting complex numbers had signed zeros, whose real and imaginary values could be either positive or negative. The phase display algorithm apparently uses atan2, which can give a pi phase shift for some of those cases.
I solved the display problem by using a conditional operator
assignment method for the complex wave that did not transfer the sign of the non-zero part of the argument to the assigned zero. Remember, when it comes to zeros, sign matters.October 18, 2012 at 05:21 am - Permalink
Were the values zero or extremely small floating point numbers?
October 18, 2012 at 05:51 am - Permalink
October 18, 2012 at 06:25 am - Permalink
