Qimaging driver
wenjiezhao
there are procedures like following one called
Execute" grabber init"
the problem is the "grabber", as Igor do not like to run it, It might need to change something which I have no idea what and how to modify the procedure. And how could I START SIDX BY IGOR BY FUNCTION?
MANY THANKS,
Wen-Jie
It would be good if you made sure that you do not have the QImaging XOP installed. Since you are using IP 6.11 it might be best if you started by installing the latest version of IGOR and then install SIDX. At this point you should be able to use SIDX per package documentation. I'm not familiar with SIDX but "grabber init" sounds as if you are trying to use the old QImaging XOP syntax which is more than likely inappropriate.
September 25, 2012 at 09:44 am - Permalink
