Is it possible to read the code for packaged IGOR functions/procedures?
daggaz
I am really curious how it works, especially as I often get multiple 'hits' on 2d-gaussian profiles and I would like to reduce this behavior (obviously preferably from my side of things). It would be nice to check things thru and see how the algorithm handles the logic of delineating everything, not to mention I would probably learn a thing or three about how to write a decent program.
Im pretty sure that the behavior I am seeing is due to thresholding of the signal+noise causing small 'islands' around the perimeters of the particles, but it would be nice to know for sure.
If you would like help figuring out what is happening then I would suggest posting some screen shots and example data that show what you're looking at.
September 17, 2012 at 05:13 am - Permalink
As 741 indicated, the algorithm is in compiled code. I developed this algorithm back in 1992 and I am not particularly keen to share it with anyone. There are no known problems with the algorithm.
It is impossible for ImageAnalyzeParticles to count a pixel twice. If you need help to figure out what is happening please send me an experiment containing the image in question and the code necessary to recreate the problem.
September 17, 2012 at 04:17 pm - Permalink
September 18, 2012 at 01:07 am - Permalink
This makes me think your problem is not with ImageAnalyzeParticles but rather with the segmentation strategy that you're using.
September 18, 2012 at 03:53 am - Permalink
I don't see how the algorithm has any bearing on your application but I'd be happy to discuss with you any issue that might help. Feel free to write to me directly.
This is yet another case where a picture would be worth 1k words. If you can "see" pixels in the threshold image then ImageAnalyzeParticles will see them too. As always, 741 has the right answer -- you need to look at the processing steps you took before particle analysis but there is no point in wasting time trying to guess at the problem without having access to the experiment.
September 18, 2012 at 02:57 pm - Permalink
