Issue with Notebook selection= command
Lars
I have here a strange behavior when using the following syntax in a function:
Notebook n_Para selection={(V_startParagraph+2, 0), endOfChars}
Only if I supply the line two times in a row, the text in the notebook gets selected as I would expected it. Then again I'm totally new to Igor.
With best regards, Lars
ps.: Igor Version is 6.3.0.1
Keep in mind that paragraph numbers are zero-based.
For debugging purposes change it to:
If you are unable to figure it out, try to create a reproducible test case and post the code here with an attached sample notebook file.
FWIW, Here is a function that tells you the number of paragraphs in a notebook:
August 10, 2012 at 08:53 am - Permalink
Out of curiosity, what happens when V_startParagraph + N > NumberOfParagraphs(nb)? Is an error thrown at run time, does the selection "stick" at the end of the notebook, or does something else happen?
August 10, 2012 at 09:05 am - Permalink
I use the search command on the below type of text. The relevant code would be:
If I pass the above mentioned selection line only one time, the cursor is placed at the beginning of the correct line but does not select the expected part of the line. That only happens after reissuing the command.
~~ Operator: Date: 2012-02-16 File Name: ShoT_001 Start Time: 10:27:21 Stop Time: 10:27:28 Notes: Ar: 10.050 mBar C2HF5: ->11.011 mBar Ar: ->950.0 mBar ~~ Bath Gas Molecule: Argon (Ar) Pre Pressure: 40.00 mbar 4.000000E+003 Pa Concentration: 1.614426E-006 mol/cm³ ~~ Probe Molecule: Cemical Molecule Molar Fraction: 1011.6 ppm Concentration: 1.633119E-009 mol/cm³ ~~ Tube Foil: 0.2 mm Temperature: 298.00 K ~~ Absorbtion Wave Length: 248.00 nm Slit Width: 0.9 mm ~~ Wave Travel Time Sensor 1 -> 2: 258.070573 µs 1.549964E+003 m/s Sensor 2 -> 3: 259.530577 µs 1.541244E+003 m/s Sensor 3 -> 4: 263.460585 µs 1.518254E+003 m/s Sensor 4 -> Window: 33.096740 µs 1.510723E+003 m/s Damping: 2.411165 % ~~ Temperature (Ideal) (Empirical) Before Reflection: 2319.133467 K 2307.194170 K After Reflection: 5093.861596 K 5055.703891 K ~~ Pressure (Ideal) (Empirical) Before Reflection: 1.092520E+005 Pa 1.099455E+005 Pa After Reflection: 5.671345E+005 Pa 5.749778E+005 Pa ~~ Mass Density Ratio (Ideal) (Empirical) Before Reflection: 3.509620 3.550173 After Reflection: 8.294595 8.472776 ~~ Mass Density (Ideal) (Empirical) Before Reflection: 2.263462E-007 kg/cm³ 2.294258E-007 kg/cm³ After Reflection: 5.349439E-007 kg/cm³ 5.475434E-007 kg/cm³ ~~ Concentration (Ideal) (Empirical) Before Reflection: 5.731627E-009 mol/cm³ 5.797856E-009 mol/cm³ After Reflection: 1.354606E-008 mol/cm³ 1.383705E-008 mol/cm³
August 14, 2012 at 10:06 am - Permalink
When you execute
endOfChars refers the the end of the currently selected paragraph at the time the command is invoked. That is, it refers to the end of the V_startParagraph paragraph, not the V_startParagraph+1 paragraph.
To achieve what you want you can change it to this:
August 14, 2012 at 10:39 am - Permalink
Regards, Lars
August 28, 2012 at 05:53 am - Permalink
