Fitting multiple peak with a complex Lorentian type fitting function
I need to to fit a certain spectra (intensity(K) vs Freq(w)) with a complex fitting function (Lorentian type)
K = K0 + A/(p-w+iD)
where complex number i=sqrt(-1)
K0 = numeric background ..usually 0 or interger (need to be found by fitting...mostly = 0)
A = Amplitude (need to be fitted… also can be supplied close value from spectra)
P= peak position (exact value need to be found by fitting..say a peak around 1640 nm)
w = center Frequency of the light used (close value can be supplied from spectra..say 1600 nm etc)
D = damping coefficient (need to be fitted)
There can be many peaks (say 4) in a single K vs w graph where each of which has certain (K,w,A,p,D) value set
I like to write a function that I can call from or a
so that after fitting I can get the values of (p,A,D) for each peak set in a table.
Can anybody give me some initial idea how to proceed.
July 27, 2012 at 04:42 pm - Permalink
How can I fit the spectrum with such function ?
July 27, 2012 at 06:31 pm - Permalink
DisplayHelpTopic "Fitting to a User-Defined Function"
To fit multiple peaks, you have two choices:
Write a version of the fit function that sums up multiple peaks, using the function you wrote.
Write the necessary functions to use your function with Multipeak Fit. To read about that:
DisplayHelpTopic "Adding Your Own Peak Function"
Writing your own peak shape for Multipeak Fit is challenging, but it can be done.
Is there a name for this peak shape?
July 30, 2012 at 12:29 pm - Permalink
