How to detect the point with the lowest value in a large number of data?
Igor_user
I have a wave that I want to subtract its minimum from it such the new wave will have the same number of data points but a minimum of 0.
Does anyone know how to do it automatically in Igor instead of going through the whole data set?
WaveStats inputWave inputWave -= V_min
where inputWave is the name of the wave you want to operate on. After doing this you can check it worked by performing wavestats on the wave again. This time V_min should be 0. For more information execute
DisplayHelpTopic "WaveStats"
from the command line.Tom
July 26, 2012 at 01:20 am - Permalink
You need to store the output from WaveMin in a variable, then subtract from the wave:
July 26, 2012 at 05:47 am - Permalink
