slowing down when processing large amount of data sets?
linyx9
I am currently using IGOR Pro for batch analysis. It involves extracting data from a directory of ascii files, performing some wave operations: wave copying/ box smoothing/ differentiation / wavestats/ Order(n) index-searching etc, and a few (line) curve fits. The main concern is, it seems to get drastically slower when I have a lot of "data sets", but I think I am only performing O(n) type calculations (i.e. traversing through each index of a wave).
To give an idea of what I mean by a "data set". It is a collection of 6-8 numeric waves that are of dimension 1000.
I collect information about each data set in list waves, i.e. containing constants and coefficients etc. I basically run through each data set by processing the list waves, and will go through the list 3 times.
I find that if I have a few 100s to about 1500 data sets, the time to completion of data processing is pretty much linear.
However, when I perform this on ~10 000 data sets it is not just 10x slower than performing on 1000. Maybe I have O(n2) or slower calculations that I ought to weed out, but is there something in Igor that would make my processing run slower just by increasing "data sets", eg am I letting it do too much virtual memory swapping?
Also, is the solution to this to perform Waveclears more often? Or, try to perform my procedures on a small batch at a time? (i.e. 10 000 data sets performed 1000 at a time with a lot of killwaves and waveclears in between?). I pretty much want to steer clear of multithread for now though,
Thanks a lot,
James
You are probably already familiar with the data folder concept but if you need a refresher:
DisplayHelpTopic "Data Folders"
November 27, 2008 at 01:28 pm - Permalink
