imagesave and normalization (bug?)
imagesave/D=16/U/T="tiff"
This results in a normalized image (max value 65534, mean 28307... ) Dropping the d and t flags and using /F instead results in the proper values, albeight single precision float values. (which is fine, but still..)
Is this a bug, or am I making some kind of error with the syntax? My test file was simply a 50x50 matrix filled with poissonNoise(400).
With the latest version here is my test:
This prints 0 as you would expect.
June 25, 2012 at 03:04 pm - Permalink
June 25, 2012 at 03:12 pm - Permalink
June 25, 2012 at 03:34 pm - Permalink
In order to reproduce your results we need to be able to run our tests under the same conditions that you did. As for OS changes: any time you are writing to disk you have machine dependent code. Experience suggests that you have to be an optimist to expect this code to always produce identical results across all platforms and all OS versions.
June 26, 2012 at 10:42 am - Permalink
