Plotting only every Nth point
kevin
Also, I use several different yWaves---something like yWave1, yWave2, etc---plotted against the same xWave, so I don't want to have to change the values of xWave.
Kevin
The short answer is that yes, you can do exactly what you want, by including the inc value in the range specification.
November 19, 2008 at 12:52 pm - Permalink
If you have a button that says "More Choices" click it.
Then select your X and Y waves and click Add.
Now you can edit the ranges in the list at the bottom of the dialog.
November 19, 2008 at 01:14 pm - Permalink
