Exporting graphs and conserving resolution, points -> pixels
I made a matrix of points (2048 x 2048) which I graph out in Igor. I would like to save this graph (as .tif for example) and have a final image resolution of 2048x2048. I am having a curiously difficult time accomplishing this task.
Currently, I make a map with (2048x2048) points, then scale x and y to this, starting at zero, with a step size of 1. Then I fill in my data using f(x,y). I remove the margins so the graph fills the entire window. Then I have tried various things, like setting height and width to absolute, with points as the units, and total values in both fields of 2048. Saving as a tif (no magnification, screen resolution) gives me a 2731 x 2731 image file. This is regardless of save graph file setings (same vs auto, points vs cm, etc..) I suppose I could calculate the factor and reverse it to force a mapping to 2048, but I would really like to avoid any transformations whatsoever, for peace of mind regarding my data.
I also tried using auto functions, and at one point got it to save at 1024x1024 (half my actual resolution) but im not sure anymore how I had gotten there. Either way, its still a transformation of my data.
It seems to me that IGOR is hardcoded to use my screen resolution as input, is there some way to get it to bypass this behavior? It would be preferable to just declare a resolution format, and let my OS decide actual physical viewing dimensions for the file.
Ian
jtigor
Rather than trying to save the graph presentation, the 2D wave itself can be saved in TIFF format using the ImageSave operation.
daggaz
Ooh. Haven't tested it yet, but this looks perfect for my current situation, thank you!
I am still curious about the original question, if anybody knows the answer. Simply a matter of understanding Igor and its mechanisms.
JimProuty
Use the power of Windows->Help Windows->WMProcedures Index!
#include <Autosize Images>
Macro OneToOnePixels()
	String graphName= WinName(0,1)
	if( strlen(graphName) == 0 )
		Abort "Need a Graph"!
	ModifyGraph/W=$graphName margin=-1	// no margin
	DoAutoSizeImage(1,-1)	// 1 pixel per image value, leave vertical flip alone. Season to taste.
After selecting this macro with your image plot top-most, choose Save Graphics and use Same Size.
Works here on Windows XP and Igor 6.22A.
daggaz
Awesome, thanks Jim. I read every help file I could think of that might have something to do with this, as well as searching the forums, all to no avail. New user, but much obliged.
