Split Axes
I would like to remove part of my axis from the graph.
I used the Split Axes Package to split the axes and I have now three separated graphs. I can remove the wave from the middle graph, but then I am left with a white gap in between the two other graphs.
How can I do to put the two remaining graphs closer together?
A.M
June 16, 2012 at 01:29 pm - Permalink
Our expectation is that you would make a single split in your axis and then adjust the axis ranges on the two pieces to show exactly what you want.
Also, it is best if you use the Split Axis package control panel for removing a split. That gives it a chance to update the data structures that store information about the splits.
June 18, 2012 at 08:59 am - Permalink
