How to make a batch fit program run on multiple cores?
sleepingawake86
Below I have pasted code for a batch fitting program. It fits a bunch of waves to a Gaussian. I am analyzing large data sets, 500+ waves each over 200 pts, and am running into the program taking like 10mins to complete. I am using an intel dual core i5 processor and I am wondering if there is anyway to work the code to run on multiple cores so that it finishes faster? Perhaps some way to split the waves in half and run each set on a different core in parallel?
function BatchGauss(Nmax) variable Nmax variable ii wave W_coef,W_sigma make /N=(Nmax) W_A make /N=(Nmax) W_Aerr make /N=(Nmax) W_width make /N=(Nmax) W_widtherr make /N=(Nmax) W_y0 make /N=(Nmax) W_y0err for(ii=0;ii<Nmax;ii+=1) string loopwave="wave"+num2str(ii) CurveFit/M=2/W=0 gauss, $loopwave/D W_A[ii]=W_coef[1] W_Aerr[ii]=W_sigma[1] W_width[ii]=W_coef[0] W_widtherr[ii]=W_sigma[0] W_y0[ii]=W_coef[3] W_y0err[ii]=W_sigma[3] endfor end
Did you try how much improvement you get using the /NTHR = 0 flag on CurveFit?
May 24, 2012 at 01:35 am - Permalink
I guess there is not so much profit from doing each curve fit in parallel with only 200 points.
The fact that you have 500+ fits to perform suggest that you want to do multiple curvefits in parallel, each on its own core.
So you might want to have a look at
which is a bit involved.
For your current appraoch I would also add the flags "/N/Q" to CurveFit.
Have you checked that single precision coefficients are precious enough?
If not you might want to add "/D" to the Make calls to use double precision.
Hope that helps,
Thomas
May 24, 2012 at 02:26 am - Permalink
The solution would be to do multiple fits in parallel. We ship an example experiment that does just that. You can probably adapt it to your situation fairly easily. To view it, select File->Example Experiments->Curve Fitting->MultipleFitsInThreads.
May 24, 2012 at 09:07 am - Permalink
Exact error is: "while executing a user function, the following error occurred: Invalid Thread Group ID or index"
Here is the code
May 24, 2012 at 01:58 pm - Permalink
Something like this:
May 24, 2012 at 04:04 pm - Permalink
June 1, 2012 at 01:23 pm - Permalink
I have a different coefficient wave for each thread but the fits try to write to the same error wave and I keep getting problems from that.
Is there a way to specify a different error wave when fitting? I know I can specify the coefficient wave, but the error wave I cant figure out.
May 31, 2012 at 03:33 pm - Permalink
But I suspect by "error wave" you mean "destination wave". For that you need /D=destwaveName.
Or perhaps you mean "residual wave". For that you need /R=residwaveName.
May 31, 2012 at 07:13 pm - Permalink
I *think* that if you do curve fits in separate threads using the (cumbersome) thread group coding, then the curve fit will take place in its own virtual data folder, and W_sigma will be distinct for each thread. I'm not sure how this applies to using the Multithread keyword, though. I would try adding a sigma wave to the input parameters of 741's RunAFit function, and inside that function copy W_sigma to that wave. To access W_sigma, you must add *after the call to CurveFit* a WAVE statement to connect with W_sigma.
June 1, 2012 at 08:42 am - Permalink
It is permitted to write to a thread worker input function's parameter wave but you can not redimension it.
It's up to the programmer to make sure that each thread gets a separate wave to write to.
I don't see how you can do this with Multithread.
June 1, 2012 at 10:07 am - Permalink
For W_sigma RunAFit() would either have to passed a 2D wave so that each iteration can access its own row or column in the wave, or it could take a wave wave. I'd probably use a 2D wave.
June 1, 2012 at 01:27 pm - Permalink
June 11, 2012 at 02:15 pm - Permalink
I am running the latest version of igor on a Macbook pro OS X 10.7, 2.8ghz i7, with 4GB of ram.
June 17, 2012 at 10:19 am - Permalink
If you can reproduce the crash, please email support@wavemetrics.com with detailed instructions we need to reproduce the crash and any Igor experiments, procedures, etc. we need to follow your directions. If you can't reproduce the crash, please at least send us the Macintosh crash log. This might give us some clues as to what is happening.
Given that you are using Igor's multithreading features, you must follow the "rules" with regards to what you do with data in threads, etc. Without at least seeing your code it is impossible to help you solve your problem.
Also, you say you are using the latest version of Igor. If you are not using the nightly build available at http://www.wavemetrics.net/Downloads/latest/ then you are not actually using the latest version. If necessary please download the latest build and check that you still get a crash. We have fixed many bugs since the latest official release of Igor (6.22A).
June 17, 2012 at 10:32 am - Permalink
