Colorscale recreation glitch
proland
colorscale/x=0 /f=0/a=RC image='' , minor=1, "\Z12"+StatNames[i] + Units[i]
When I save the graph recreation macro, or close the program, there is an error when it is recreated. The colorscale is recreated using the command
ColorScale/C/N=text0/F=0/A=RC/X=0.00 /C/N=text0minor=1
The second /c/n can not be there and is causing an error. This command was automatically created by Igor as part of the graph recreation macro for my image with a color scale. Any thoughts as to how I can resolve this?
For the short term, eliminating the minor ticks avoids the error, but I am confused as to why this is happening in the first place.
Try the latest nightly build here:
http://www.wavemetrics.net/Downloads/latest
and try re-saving the experiment. Note: the fix applies to *saving* the recreation macro, so the error will still occur when you *open* the experiment file, but once you resave the experiment it should be okay.
You can see if Igor is generating fixed recreation code by using Ctr+Y (command-Y on Macintosh) to save or update the window recreation macro.
Sorry for the trouble.
May 24, 2012 at 04:18 pm - Permalink
