Curve Fitting an integral that has limits that are from a wave
I am trying to fit data to an integral whose limits vary for each point - the Callaway model for thermal conductivity. I have a wave with x data and a wave with y data (Nine points in each wave). I need to fit the data to an integral whose limits go from 0 to a constant/x[i] for each x[i] and y[i] pair. Everything compiles, but IGOR tells me I have a BAD USER FUNCTION FORMAT when I try to fit the data. Below is what I have tried so far. Any help would be appreciated!
Thanks
//This is the user-defined fitting function:
Variable/G Alpha=A, Beta1=B1, Beta2=B2, Length = L //Parameters to be fitted
Variable/G Temp=T //Wave with the independent variable
f(T) = Real(Integrate1d(eqn, .001, 281/Temp)) //This is what I want to do, but ...
//This is the function it calls:
Function eqn(x)
Variable x
NVAR Alpha, Beta1, Beta2, Length
NVAR Temp
// A bunch of variables - The constants are defined at the top of the procedure file as they should be, I just stuck them below for now
Variable Pre = (kB/(2*Pi*Pi*c))*((kB*Temp/hbar)^3)
Variable Tp = Alpha*x^4*Temp^4
Variable Tb = c/Length
Variable Tu = Beta1*exp(-ThetaDebye/(a*Temp))*(T^5)*(x^2)
Variable Tn = Beta2*(Temp^5)*(x^2)
Variable Tc = (Tp+Tb+Tu+Tn)^-1
// The equation I want to integrate
Return Pre*Tc*((x^4)*exp(x))/((exp(x)-1)^2)
//The constants
Constant kB = 1.38e-23
Constant ThetaDebye = 281
Constant c=2790
Constant a= 1
Constant hbar=1.05459e-34
DisplayHelpTopic "User-Defined Fitting Function: Detailed Description"
FuncFit accepts a variety of different format in order to handle various situations.
Your function lacks an input wave corresponding to the coefficient wave. That wave has the adjustable parameters that are the point of the curve fit. So my next question is- what are the adjustable parameters in your function?
Your subject line says you want to get the limits of integration from a wave, but in fact you have an equation for the limit that depends on X (which I presume is the independent variable in your curve fit). So you don't need to get the limits from a wave, you need to compute it depending on the value of X.
Oh, wait- I just understood your bits of code and commands. You need to wrap up the three lines at the top in a user-defined function of the appropriate format. Something like this:
There is still a problem- your command
Real(Integrate1d(eqn...)
suggests that you expect a complex value from Integrate1D, but Integrate1D returns a real value. It only integrates real-valued integrands. So we may not be there yet...John Weeks
May 24, 2012 at 09:02 am - Permalink
May 24, 2012 at 11:14 am - Permalink
