small multithread errors
ubi
To be a bit more precise: Each x point is the result of the the difference of two different datasets proceeded by the following function.
Threadsafe FUNCTION fitthematrix_realth(srcwv, tmpwv,outwv,row)
WAVE srcwv, tmpwv, outwv
variable row
variable i
tmpwv = srcwv[row][p]
CurveFit/N/Q/L=100000 /NTHR=1 poly 4, tmpwv /D
wave fit_dumper, M_Covar, W_coef, W_fitConstants, W_ParamConfidenceInterval, W_sigma
wavestats/Q/M=1 fit_dumper
outwv[row] = 0.0009 * V_minRowLoc
killwaves/Z fit_dumper, M_Covar, W_coef, W_fitConstants, W_ParamConfidenceInterval, W_sigma
END
variable row
variable i
END
In the main function the loop which calls the fit procedure looks like, which is basically copy&pasted from the igor help files:
Variable n,actrow,nthreads= ThreadProcessorCount
Variable mt= ThreadGroupCreate(nthreads)
Variable ttime= stopMSTimer(-2)
for(actrow=0;actrow<DimSize(fieldwv,0);)
for(n=0;n<nthreads;n+=1)
ThreadStart mt,n, fitthematrix_realth(fieldwv, dumper,resultingfield,actrow)
actrow+=1
if( actrow >= DimSize(fieldwv,0) )
break
do
variable tgs= ThreadGroupWait(mt,1000)
while( tgs != 0 )
variable dummy= ThreadGroupRelease(mt)
Variable mt2= ThreadGroupCreate(nthreads)
for(actrow=0;actrow<DimSize(zfieldwave,0);)
ThreadStart mt2,n, fitthematrix_realth(zfieldwave, dumper,resultingnofield,actrow)
actrow+=1
if( actrow >= DimSize(zfieldwave,0) )
break
do
variable tgs2= ThreadGroupWait(mt2,1000)
while( tgs != 0 )
dummy= ThreadGroupRelease(mt2)
actrow+=1
break
do
while( tgs != 0 )
actrow+=1
break
do
while( tgs != 0 )
Where is my error?
May 8, 2012 at 10:43 am - Permalink
- Why is tmpwv passed in as an argument? Each thread will overwrite tmpwv - its contents are undefined.
- You reference a wave called fit_dumper. I don't see one being created. Remember that all threads have their own data folder hierarchy, independent from the 'standard' Igor hierarchy.
That said, here's how I would implement it (note - I assume that your output is 1D and that there is one point for each row in the source matrix).
variable row
variable i
CurveFit/N/Q/L=100000 /NTHR=1 poly 4, srcwv[row][] /D
// do something with the results of the fit and WaveStats
return 0.0009 * V_minRowLoc
END
Function DoTheWork(srcWave)
wave srcWave
Make /O/N=(DimSize(srcWave, 0)) /D outputWave
MultiThread outputWave = FitWorker(srcWave, p)
May 8, 2012 at 12:44 pm - Permalink
Great that fixed the problem. Indeed I have to create tmpwv in the thread. However your suggestion seems to be a bit "lighter", I'll give a try.
May 9, 2012 at 02:07 pm - Permalink
