I have two graph (Graph1 , Graph 2) in two different igor experiment file (exp1.pxp and exp2.pxp) . How can I open two graph in a new experiment file ? I tried to save two individual graph from the experiment file (save "Save Graph copy") ..and opened one of them (say Graph 1) and then tried to drag the second.., it doesnot work.
Is there anyway other than copying the data of the second and to paste in a new blank table in the experiment file that contain and plottting new graph Graph 2 from that table?
Thank you so much...Its working great..although one little problem ..somehow after I merge the two graph ...in the "append wave" menu I see only the name of the first wave i,e the wave I opened first...2nd wave name i,e the wave that was merged by using "Open experiment"- Merge menu ...does not appear in the list.
DisplayHelpTopic "Merging Experiments"
You already know about Save Graph Copy so the second one is what is missing.
April 12, 2012 at 09:39 am - Permalink
April 12, 2012 at 10:10 am - Permalink
April 12, 2012 at 12:11 pm - Permalink
Your dialog wave browser may be set to not show data folders. Click the little triangle in the lower-lefthand corner and set it to show data folders.
For details:
April 12, 2012 at 12:25 pm - Permalink
