Extract contour waves using a function?
s.r.chinn
#include<Extract Contours As Waves>
adds the wave-from-contour extraction operation to the Graph menu, but this must be performed manually. I did try inspecting the code in the included ipf, but it is pretty opaque (to me).As an alternative the Manual suggests
Another way to copy the traces into a normal wave is to use the Data Browser to browse the saved experiment; the contour traces are saved as waves in a temporary data folder whose name begins with “WM_CTraces_” and ends with the contour’s “contour instance name”.Since I created the custom contour level , I think I can construct the necessary instance name to use in a function. However, after I created a test image with contours, this folder was nowhere to be found. If it is temporary, how can it be accessed?
I would appreciate any suggestions.
(IP 6.22A, WinVista)
April 4, 2012 at 10:02 am - Permalink
Thanks for your help. I initially thought I had solved the problem with the following example:
The new contour level was added to the Graph0 image plot, and the new extracted contour waves appeared in the Data Browser. However, these new waves each had 0 points. What did I do incorrectly?
April 5, 2012 at 04:27 am - Permalink
April 5, 2012 at 09:18 am - Permalink
I was confused in the application of the AppendMatrixContour help file contents:
This test example was somewhat artificial. However, fitting a contour shape of real data can be useful.
April 5, 2012 at 10:12 am - Permalink
April 6, 2012 at 10:08 am - Permalink
