Igor keeps prompting an error message
Igor_user
I was trying to load a XRD pattern into Igor and use it to rescale from '2theta' to 'k'.
Upon loading I renamed wave0 & wave1 to '2theta' & 'int' respectively.
then,
Duplicate '2theta' 'k'
'k'=2*[sin('2theta'/2)]/1.5425
but Igor keeps prompting up an error message saying "unknown or inappropriate name or symbol", when in fact I was using exactly the wave names I just defined.
I seldomly experience the same kind of problem in the past.
So, does anyone know what's the problem? Is it because igor doesn't realise the square bracket []?
I guess it's because when you use square brackets Igor expects an x-value or a x- range of a wave. So in this case it doesn't know what to do.
Just a comment: I personally would avoid liberal names, e.g. 2Theta, which needs to be addressed with ' '. This is asking for trouble especially in user functions. I'd call the wave TwoTheta instead. And for the wave k you don't need single quotes.
March 12, 2012 at 01:02 am - Permalink
March 12, 2012 at 10:10 am - Permalink
