Trace marker size from wave
In the attached graph there is a data wave plotted (on top of an image) as markers only. The color and size of the markers are set by selecting the same data wave in the customize marker dialog ("set as f(z)"). The min and max of the z-range (for both marker size and color) are set to less than the full range of values in the data wave. Marker color behaves as I expected, all points of the wave with values greater than the max setting for the z-range appear to be the same color. However, marker size does not seem to follow this same behavior. I exected that all points with values greater than the max setting would be the same size. Based on the coloring of the markers this is not the case.
Have I misunderstood the intended funtion of the marker size or have I set something incorrectly? Or... something else?
I have attached an image of the graph and the "set as f(z)" dialog showing the settings for the data wave markers.
Jeff
Since marker size is just a number, it can be, and in fact is, extrapolated. The min/max just set the proportionality.
This is the f(z) marker size calculation Igor uses:
markerSizeInPoints[p]= min(400,max(1, (zwav[p] - zMin)/(zMax-zMin)*(markerSizeMax-markerSizeMin) + markerSizeMin))
Note that unlike the zColor settings, the dialog has no "before first marker size" or "after last marker size" settings.
So you'll need to limit your zWave accordingly. With your settings, this won't change the f(z) colors you get.
Gotcher. Particularly if you meant...
( ( (zwav[p] - zMin) / (zMax-zMin) ) * (markerSizeMax-markerSizeMin) ) + markerSizeMin
Does "min(400,max(1, ... " mean the maximum marker size is 400 and the minimum is 1?
Now that I understand, I see that I will have to change the zwave to get the result that I want. Perhaps you would consider adding those settings in the future?
Jeff
Yep.
