including erros when fitting
pascal
i can't find any way to include my errors (wssr, esd..) when i fit to experimental data. Also, how do i produce error-beams in a graph?
I'm currently coping with four different softwares for fitting, plotting, ... surely igor must be able to do anything sigmaplot or excel or any standard fitting-software can do..?
thanks a lot
pascal
DisplayHelpTopic "Weighting"
You may benefit from reading the Curve Fitting chapter in the Igor Manual, User's Guide Part 2.
Read about error bars on graphs with this command:
DisplayHelpTopic "Error Bars"
It would probably be a good idea, if you haven't done it yet, to go through the Guided Tour, which takes two or three hours, but will save time in the long run by introducing you to the way Igor thinks. Use this command:
DisplayHelpTopic "Getting Started"
October 23, 2008 at 01:50 pm - Permalink
