move segment of a wave/graph
Hi How can I move a segment of a wave in a graph by a fixed ditance ( kind of "block move" or "segment move" along y direction )
I tried the segment mover (cntl + edit wave ) in Poly tool but it does only for adjacent points.
Is there any way for example by placing two cursors on the graph at points say at (x1,y1) and (x2,y2) and then shifting (visually/by dragging the curve portion) all the points within (x1,y1) and (x2,y2) to new location (x1,y1-5) ...(x2,y2-5) where all the points within (x1, y1) and (x1,y2) also moves by the same amount ( -5) .
The arithmatic panel can do the shift but for it works on whole graph, is there any way to do it on section of a graph.
There is no way that I know of to do this with the mouse.
Here is a function that does it programmatically:
Function AddToXYPairSegment1(xWave, yWave, startX, endX, offset)
    Wave xWave, yWave
    Variable startX, endX
    Variable offset
    Variable numPoints = numpnts(xWave)
    Variable i
    for(i=0; i<numPoints; i+=1)
        Variable xval = xWave[i]
        if (xVal>=startX && xVal<=endX)
            yWave[i] += offset
Here is another function that does the same thing but much faster:
Function AddToXYPairSegment2(xWave, yWave, startX, endX, offset)
    Wave xWave, yWave
    Variable offset
    yWave = (xWave>=startX && xWave<=endX) ? yWave+offset : yWave
Execute this for help on ?:
DisplayHelpTopic "? :"
Thanks a lot for your reply.
I tried to get xwave and ywave from cursor but it didnt work. Somehow I didnt able to define the function properly.
Can you put some light !!
Menu "Segment Move"
"Move Segment ...", AddToXYPairSegment2("", "", "", "",10)
Function AddToXYPairSegment2(XWave, YWave, startX, endX, offset)
Variable offset
WAVE/Z w = CsrWaveRef(A)
if (!WaveExists(w)) // Cursor is not on any wave.
return NaN
Variable  startX = xcsr(A)
Variable endX = xcsr(B)
Wave YWave = w
Wave XWave = CsrXWave(A)
    YWave = (XWave>=startX && XWave<=endX) ? YWave+offset : YWave
    DisplayYWave vs XWaveA
Try this:
Function AddToXYPairSegment3(offset)
    Variable offset
    WAVE/Z yWave = CsrWaveRef(A)
    if (!WaveExists(yWave))         // Cursor is not on any wave
        return -1
    WAVE/Z xWave = CsrXWaveRef(A)
    if (!WaveExists(xWave))         // Cursor is not on XY pair
        return -1
    Variable startX = hcsr(A)
    Variable endX = hcsr(B)
    if (startX > endX)
        return -1
