multi general text loading
fariman
I want to write a proc by which I can load all the text files in a folder. the files are categorised by name, for example basename_001, basename_002 and so on.
for loadindg the files simultanously I have to have a flexible path, which changes automaticaly after it imports the first file.
I wrote a test proc in which it uses the loadwave function. after I execute it it ask for the path, I give the path by browsing and choosing the first file, so it store the full path to the s_path string, then I want to use a loop in which there is another loadwave function except the path is coming from the s_path+index.
index goes up one by one and it continues until loading all the waves. but in any form I used the path,the procedure doesnt accept it while compiling, and mention: ill formed path,
would any body help please
To include igor code in these forum postings, put <igor> and </igor> tags around the text, like this:
<igor>
Function/S ListFilesOfType(dataFolderStr,type,fileTypeStr)
String dataFolderStr
Variable type // popup,"Igor Binary;Igor Text;General Text;Delimited Text;"
String fileTypeStr // usually "TEXT" for *.txt files on Windows
String files=""
if( type == 1 )
files= IndexedFile($dataFolderStr,-1,fileTypeStr) // list of all files with matching type
if( type == 2 ) // Igor Text, either "TEXT" or "IGTX" (.txt or .itx)
// open each TEXT or IGTX file, and if the first line is "IGOR", add it to files
files= IgorOrTextFiles(dataFolderStr,fileTypeStr,1) // on Windows, *.txt (or user's file type)
if( CmpStr(fileTypeStr,"IGTX") != 0 ) // avoid listing a file twice
files += IgorOrTextFiles(dataFolderStr,"IGTX",1) // on Windows, *.itx,
files= IgorOrTextFiles(dataFolderStr,fileTypeStr,0) // on Windows, *.txt
return files
</igor>
and it will be nicely formatted:
November 12, 2010 at 02:10 pm - Permalink
I found two functions from Igor examples which do the thing that I want, but there still exists a problem
suppose that I have a folder with 100 text files in it, when I call this function the window of loading waves apears and I have to
click on load button 100 times. if I want to cancel now I have to click cancel button 100 times again. I am not satisfied with this, is there any way to load 100 text files at once.
thank you in advance
November 14, 2010 at 01:37 pm - Permalink
November 13, 2010 at 04:23 pm - Permalink
November 13, 2010 at 06:47 pm - Permalink
I excecuted it and it worked properly. both advices were so helpful.
I learned a lot here. I will continue learning and discussing in this nice forum
thanks again
November 14, 2010 at 05:44 am - Permalink
I merged two functions and edited it a little. now it works nicely for me so I put it
here for whom it may be useful to import all the general text files in a folder at once.
November 14, 2010 at 01:27 pm - Permalink
I've copied your program to Igor and tried to use it.
I got an error message that said "A non-existent data folder was referenced while accessing a child data folder".
My command line was: "LoadAndGraphAll(C:\Users\Aviv\Documents\Aviv\flex\Flex52 _Pani_90_30\)"
I'd appreciate any assistance on the matter, since you guys wrote that this program works for you.
Thanks you,
Aviv
December 22, 2011 at 02:04 am - Permalink
LoadAndGraphAll("C:\Users\Aviv\Documents\Aviv\flex\Flex52 _Pani_90_30\")
You also need to use double backslashes to have a backslash included in the path. Igor uses backslash to included special characters (such as tabs) in strings. You can also substitue a colon for a backslash in the path. Internally, Igor can use this Mac path separator convention. If you use double backslashes you command should look like this:
LoadAndGraphAll("C:\\Users\\Aviv\\Documents\\Aviv\\flex\\Flex52 _Pani_90_30\\")
December 22, 2011 at 05:59 am - Permalink
I have another question on this part, if I want to use the filename variable and rename every wave loaded to it's filename + an extention, such as:
wave0 = filename_loaded
filename includes the file type "aviv.txt" instead of just "aviv".
I've tried using strcpy, strncpy, strcat, etc, but none of these commands work in Igor.
How can I shorten the filename?
Thank you again,
Aviv
December 29, 2011 at 02:50 am - Permalink
December 29, 2011 at 05:30 am - Permalink
ParseFilePath(3, filename, ":", 0, 0)
where filename is your input file name with extension (with or without the path). If filename includes the path then the ":" above specifies the path separator. If you get the path from Igor, regardless of whether you are working on Mac or Windows, a colon will be the path separator. In effect this function removes everything after the final ".".
For example:
print ParseFilePath(3, "gabbagabba.hey", ":", 0, 0)
prints:
gabbagabba
December 29, 2011 at 01:44 pm - Permalink
January 5, 2012 at 02:23 am - Permalink
I have also been attempting to write a macro which I can use to load all text files within a folder, unfortunately these are not categorised the same way as fairman's and are named as shown in the following example:
p100kimage545836.tif.dat
p100kimage545837.tif.dat
....etc. etc.......
p100kimage545936.tif.dat
Ideally I would also like the macro to append the new waves into seperate graph windows as they are loaded, as demonstrated using the following macro for an individual 2D intensity plot, unfortunately there are >100 scans make in each scan so it's not really feasible to do this individually!:
Initially I tried to accomplish this by using a do loop within a do loop, however, due to my lack of knowledge w.r.t. Igor syntax I have not found a means by which to read every file within a directory and allocate systematic wavenames to these files (wave0, wave1 etc.). Therefore after reading Fariman's original query I attempted to use the solutions that were suggested.
Unfortunately the following macro was only capable of loading a single wave and I'm unable to see how it differentiates from that suggested by JimProuty
Whereas the following macro failed to load any waves whatsoever and I'm also lost as to why.
As you can probably establish I am fairly new to script writing as a whole so any suggestions, no matter how condescending you feel they may be, will be much appreciated.
Jon
February 18, 2012 at 09:58 am - Permalink
Next, in Load2DImage, this statement:
should be:
Finally, all new code should be written as functions, not as macros. To understand why, execute:
Here are the procedures rewritten as functions:
February 18, 2012 at 11:22 am - Permalink
Thank you very much for the quick reply, unfortunately when attempting to execute the functions posted I was met with "syntax error: expected string variable or string function".
Could this be effected in anyway by my using Igor 5.04B (on a mac)
Regards
Jon
February 19, 2012 at 09:47 am - Permalink
You need to provide all of the parameters when calling a user-defined function, like this:
If you omit the parameter (an empty string in this case), you will get the "expected string" error.
February 19, 2012 at 10:14 am - Permalink
