how to partition a wave (newbie)
Simon87
I use Igor pro since a few days only, so please don't be to severe.. and even worse : as you can see, I can't write english very well !
My problem is that I don't know how to create many waves from a single one, automatically. My data are in a single wave (wave0), and I want to partition it in many waves, but without using the "make" operation manually, for each of them. Moreover, I would like to automatically name it, for exemple using an increment.
I tried something like that :
Function dada(nbang, size)
variable nbang, size
variable i
wave wave0
for (i=0;i Make/N=(size)/D/O ang //something's missing here
appendtotable ang
ang[0,size-1]=wave0[p+size*i]
but off course, there is only one wave called "ang" and it only contains the last "size" values from wave0. And I would like "nbang" waves (named according the "i" increment, if possible), each of them containing "size" values.
Thank you !
Simon
variable i
wave wave0
for (i=0;i(nbang;i+=1) // < instead of (, but it seems it doesn't work here
appendtotable ang
Thank you !
Simon
December 2, 2011 at 04:04 am - Permalink
A
December 2, 2011 at 06:18 am - Permalink
December 2, 2011 at 06:32 am - Permalink
When you post code here, make sure that you surround it with <igor></igor> tags. Otherwise, when the system sees greater than and less than symbols (> and <), it thinks they are part of HTML tags.
December 2, 2011 at 06:53 am - Permalink
