Crashes caused by replace wave dialog
pb
The behavior is pretty quirky. The crashes only come when replacing images, not traces. And it (usually?) doesn't occur when you hit the "Do" button, like you'd expect. Instead, it seems to happen when you're browsing in the drop-down menu for the image wave you want to replace the current one with.
I always kinda figured that the WM guys knew about this and had it on the back burner, but it's been a long time... so maybe not??? Have others noticed the same issues, and could a fix be on the way?
You don't say what version of Igor you are using. I suggest you update your Igor to the latest shipping version (6.22A) if you aren't there already. Do that by using the Help->Updates menu. Then, I suggest you download the latest nightly build of the application from http://www.wavemetrics.net/Downloads/latest/ (instructions are on that page for how to use it). I don't remember us fixing any crashes in the Replace Waves dialog since our last official release, but we have fixed a number of crashes in other places. The fact that you say the crash happens while browsing for a wave suggests that the crash may not be specific to the Replace Waves dialog.
It's difficult for us to fix a crash that we can't reproduce ourselves. So if you can send us a recipe that reliably reproduces the crash we should be able to fix it. If you come up with a recipe, please also send us any experiment or procedure files we need to use to follow your recipe. It's best to send that all to support@wavemetrics.com instead of posting here (actually, all crash reports should be sent directly to us so that we can make sure they go to the programmer responsible for the crash). If you get the crash on Macintosh, please also send us the crash log (click the Report button in the dialog that the system puts up after a crash, and copy the full text in that window and email it to us). Note that using the Apple crash reporting tool doesn't actually send the report to us (and Apple doesn't send it along to us either).
If you can't give us a detailed recipe, it would help if you could at least provide as many details as possible about what you were doing and the state of the dialog.
In the future, if Igor crashes and you can reproduce the crash, send us the recipe and we will do our best to fix the crash.
November 30, 2011 at 07:18 am - Permalink
November 30, 2011 at 08:42 am - Permalink
November 30, 2011 at 10:58 am - Permalink
I have also added an error message for that situation, and added an error message for the situation of missing replacement wave for a regular graph trace as well.
Igor should never crash; we try to fix crashes as soon as we know about them, typically the same day we get the report if we can reproduce it. So, no, it wasn't on the back burner. I suspect few people use the Replace Wave dialog for images or contours, and that's why we haven't fixed it previously.
Again, thank you for taking the time to report the crash.
November 30, 2011 at 11:31 am - Permalink
December 1, 2011 at 06:55 am - Permalink
