Xcode 4 requires XOP Toolkit 6.02 [was Xcode 4 Not Yet Recommended For XOP Development]
![](/profiles/wavemetrics/themes/wavemetrics/images/icons/employee-icon.png)
hrodstein
Judging from the comments on the Xcode mailing list, it appears that Xcode 4 is a significant departure from Xcode 3.
Unless you are an expert with time to spare, I recommend sticking with Xcode 3 for XOP development until further notice.
November 3, 2011 at 10:10 pm - Permalink
If you are a licensed XOP Toolkit user and you previously downloaded XOP Toolkit 6, you can download the latest XOP Toolkit using the same download link.
If you are a licensed XOP Toolkit user and you never downloaded XOP Toolkit 6, you need to get the download link from WaveMetrics sales.
November 4, 2011 at 09:15 am - Permalink
January 24, 2012 at 04:57 pm - Permalink
This is an error in Xcode 4.2 only. It was not an error in Xcode 4.1 or before. The error occurs because Apple dropped support for the "GCC 4.2" compiler in Xcode 4.2.
The solution is to set the compiler to "LLVM-GCC 4.2", which is still supported in Xcode 4.2. This uses the GCC 4.2 compiler for parsing and LLVM compiler for code generation.
Make sure to set the compiler at both the project and target levels. Also you may need to clean the project before recompiling.
January 25, 2012 at 02:34 am - Permalink
January 25, 2012 at 08:05 am - Permalink
I you have the Xcode "Live Issues" turned on, I recommend you turn it off (File->Project Settings). It is not consistent with the GCC 4.2 parser because it uses LLVM to look for issues that are often not issues with GCC.
If you don't mind the inconsistency then you can leave Live Issues on.
January 25, 2012 at 01:41 pm - Permalink
"First parameter of 'main' (argument count) must be of type 'int'"
anyone any idea?
laurens
May 23, 2012 at 09:11 am - Permalink
Apple dropped support for the "GCC 4.2" compiler in Xcode 4.2 (without even a mention in the Xcode 4 release notes;).
Fortunately they still support the "LLVM-GCC 4.2" compiler (GCC 4.2 parser, LLVM code generator) which does not complain about the main function. So change your project settings to use the "LLVM-GCC 4.2" compiler and it should work.
I will address this in XOP Toolkit 6.03 some time "soon".
Another solution is to change main to XOPMain. See "The Main Function" in Chapter 12 of the XOP Toolkit 6 manual for details. This technique requires that you run with Igor Pro 6.20 or later.
May 23, 2012 at 01:03 pm - Permalink
