VISAError
lin
I'm running Igor Pro v. 6.2.2.2 and whenever I start it, it shows me the following error message:
"VISA Error"
"The specified module could not be found."
I have put the VISA file in "Igor Pro 6 User Files\Igor Extensions" but the error does not disappear.
Thank you for your help :).
lin
You have two "Igor Extensions" folders. To understand this, execute this in Igor:
If you want to use the VISA XOP then you need to install the VISA library. This is explained in the VISA Help file.
August 18, 2011 at 01:40 pm - Permalink
