Igor 6.22 has been released
JimProuty
This is primarily a bug-fix release, though there are a few new features:
- Added log colors to trace f(z) color, image plots, and contour line colors
- Date/time axes in graphs can now be reversed
As always, choose "Updates for Igor" from Igor's help menu to find the best updater for the version you are running, or use the direct links below.
IGOR Pro 6.22 is available as a free update to licensed users of the English version IGOR Pro 6.0 and later.
• Macintosh users of IGOR Pro 6.0 or 6.1 should download the IGOR Pro 6.22 installer:
http://www.wavemetrics.net/Downloads/Mac/Igor6.dmg
• Windows users of IGOR Pro 6.1 or 6.2 may download the IGOR Pro 6.1 to 6.21 updater:
http://www.wavemetrics.net/Updaters/WinUpdateIgor61ToLatest.exe
• Windows users of IGOR Pro 6.0 should run the IGOR Pro 6.22 installer after uninstalling IGOR Pro 6.0:
http://www.wavemetrics.net/Downloads/Win/setupIgor6.exe
• Windows users who wish to run the 64-bit beta version of Igor (6.23B01) should see this page for instructions and the download link:
http://www.wavemetrics.net/Updaters/ReadMe%20(64-bit).html
For a detailed list of bug fixes and changes, see:
http://www.wavemetrics.net/Updaters/WhatsChangedSince6.1.html
I can't get this to work. When I set a negative tau I get a extreme 'cliff' towards negative values instead of a peak with the tail to the left. How does this work?
July 11, 2011 at 04:54 am - Permalink
July 12, 2011 at 10:02 am - Permalink
July 14, 2011 at 01:37 am - Permalink
So I tried doing the fit from scratch: I clicked the Auto-Locate Peaks Now button, changed to ExpModGauss peak type, and did the fit. The result was exactly the same fit but with positive Gauss Width. If I now change GaussWidth to negative, it looks just like your case where positive GaussWidth goes bad. With negative GaussWidth all the derived parameters like FWHM, etc., are garbage.
Ah- I see bugs... I'm working on it.
July 14, 2011 at 10:03 am - Permalink
I have changed the code so that it updates the coefficients and simply completely re-computes the graph curves. This is more robust in that if something goes wrong, it will self-correct.
The new version of the procedure file is attached. It is compressed- unzip it first. Find your Igor Pro folder (Help->Show Igor Pro Folder) and then navigate down to WaveMetrics Procedures:Analysis:Peak Fitting:. Drag the new, unpacked file into Peak Fitting to replace the old one. The new file will be included in the next minor release.
July 14, 2011 at 10:51 am - Permalink
