Convert Igor date into Excel
J-E Petit
This is my first post on this forum, and I am also fairly new with Igor, so my questions may look trivial.
I have an Igor file with a time serie of random data. I need to plot them on Excel, but both softwares seem to handle dates differently (for example: 06/01/2011 8:49:11 gives 3389770151 in Igor and 40695,3674884259 in Excel). However, the ratio of those 2 numbers are constant (fairly the same, but not constant).
Is there a simple way to convert Igor dates to Excel dates?
Thanks for your help
My simplistic approach was to set excel's default to 1904 system, divide Igor's value for 06/01/2011 8:49:11 by 86400 (secs/day) in excel and change the cell format to date/time. The result reported in excel is 6/1/2011 10:49:11. Note that is 10:49:11 not 8:49:11 as you reported. Don't know why.
This is a quick & dirty approach. Maybe it will serve as a starting point for you and maybe, most likely, someone will have a significantly more elegant approach.
PS The Igor value for 6/1/2011 8:49:11 AM should be 3389762951.
June 29, 2011 at 10:18 am - Permalink
June 29, 2011 at 01:28 pm - Permalink
