Learning Structure Based Programing
Being a self-taught Igor programmer (no one else to blame), I would like to continue to upgrade my skills. Is there a good tutorial source to teach myself structure based programming? I appreciate not just examples but also a bit of high level framework discussions of what is the goal of the technique and the pros and cons.
Thanks In Advance.
You can always to a print of a structure at any point to see its contents, and following the progress of a procedure using the debugger helps too.
As for pros/cons, one advantage of structures is that they can be stored and retrieved as "preference" sets. Another is, they can be tools to generate initialization sets ...
June 6, 2011 at 11:49 am - Permalink
