ReWrite program from Visual Basic to Igor
randomz_raf
I try to rewrite or convert the visual basic program (i got it from my friend) in Igor Procedure for my data acquisition.
I don't know if it suitable or not to post this in this forum.
I just want to know your opinion if my Igor procedure is similar with the Visual Basic or not?
This is my Igor Procedure:
#pragma rtGlobals=1 // Use modern global access method.
Function tdcDmaRead() // Public Function tdcDmaRead(ud As Long, addr As Integer, byte_count As Long) in VB (Visual Basic)
Variable IX,IY
Variable DataImage
variable/G lsb1,lsb2, msb1, msb2
String PSDbuffer
Variable UnitDescriptor,UdPSD,cmd,addr
String RdBuffer= PSDbuffer
UdPSD=UnitDescriptor
tdcprepare(UdPSD, cmd)
for (IX=1;IX<=128;IX+=1)
for (IY=1;IY<=128;IY+=1)
NI4882 ibrd= {UdPSD,4}
PSDbuffer = S_value
lsb1=char2num (Rdbuffer[0])
lsb2=char2num (Rdbuffer[1])
msb1=char2num (Rdbuffer[2])
msb2=char2num (Rdbuffer[3])
Print "dalam drawimage: " , lsb2,lsb1, msb2, msb1
Printf "dalam drawimage: %s/x" , lsb2,lsb1, msb2, msb1
Make/O/N=(128,128) rawdata
rawdata=rawdata+(msb1*16777216)+(msb2*65536)+(lsb1*256)+lsb2
Print "dalam drawimage" , lsb2,lsb1, msb2, msb1
Print "DataImage",rawdata
Function tdcprepare(UdPSD, cmd) //This is a Public Function TdcPrepare(ud As Long, func As Integer, addr As Integer, byte_count As Long) in VB
Variable cmd
Variable UdPSD
String cmdStr1
String charB,charC,charD,charE,char0
String/G PSDbuffer
Variable response,v,b,c,d,e
print " "
print "Transfer TDc"
cmd=0x05
TdcFunc(UdPSD,cmd)
b=0xFF //cnt.msb = &HFF in VB
c=0xFC//cnt.lsb = &HFC inVB
d=0x00 //adr.msb = 0 in VB
e=0x00 // adr.lsb = addr in VB
charD=num2char (d)
charE=num2char (e)
cmdStr1= charD+charE +"\0"
NI4882 ibwrt={UdPSD,cmdStr1,strlen(cmdStr1)}
print "length UdPSD:", strlen (cmdStr1)
charB=num2char (b)
charC=num2char (c)
cmdStr1=charB+charC +"\0"
Function TdcFunc(UdPSD,cmd)// This is a Public Function TdcFunc(ud As Long, func As Integer) in VisualBasic
Variable UdPSD,cmd
String cmdStr1
Variable v
String PSDbuffer
print "UdPSD cmd:", cmd
cmdStr1=Num2Char(cmd) +"\0"
v=0x00
NI4882 ibeos = {UdPSD, v}
NI4882 ibwrt={UdPSD,cmdStr1, strlen(cmdStr1)}
NI4882 ibrd={UdPSD,strlen(cmdStr1)}
PSDbuffer=S_value
Variable IX,IY
Variable DataImage
String PSDbuffer
PSDbuffer = S_value
Variable cmd
Variable UdPSD
String cmdStr1
String/G PSDbuffer
print " "
cmd=0x05
TdcFunc(UdPSD,cmd)
charD=num2char (d)
charE=num2char (e)
charB=num2char (b)
charC=num2char (c)
Variable UdPSD,cmd
String cmdStr1
Variable v
String PSDbuffer
v=0x00
PSDbuffer=S_value
and this the Visual Basic program:
Dim rt&, i&, j&, mulai&, selesai&, msb1&, msb2&, lsb1&, lsb2&
Dim recvbuffer As String, dummy As String
rt& = TdcPrepare(ud, DMA_READ, addr, byte_count)
If rt& <> 0 Then
MsgBox "Error while Preparing DMA Read", vbCritical, "SANS Measurement and Control"
tdcDmaRead = -1
Exit Function
End If
'Open "C:\rawdata\hasil.txt" For Output As #1
Open "hasil.txt" For Output As #1
For i& = 0 To 127
For j& = 0 To 127
If i& = 127 And j& = 127 Then
Print #1, i&, j&, rawdata(i&, j&)
Exit For
End If
recvbuffer = Space$(4)
ibrd ud, recvbuffer, 4
If (ibsta And EERR) Or (ibcntl = 0) Then
MsgBox "Error while reading DMA", vbCritical, "SANS Measurement and Control"
tdcDmaRead = -1
Exit Function
End If
lsb2& = Asc(Left(recvbuffer, 1))
lsb1& = Asc(Right(Left(recvbuffer, 2), 1))
msb2& = Asc(Right(Left(recvbuffer, 3), 1))
msb1& = Asc(Right(Left(recvbuffer, 4), 1))
rawdata(j&, 127 - i&) = rawdata(j&, 127 - i&) + (msb1& * 16777216) + (msb2& * 65536) + (lsb1& * 256) + lsb2&
Next j&
Next i&
Close #1
End Function
Dim rt&, Point_Address As String, Point_Count As String
Dim adr As memaddr, cnt As ByteCnt
adr.msb = 0
adr.lsb = addr
'((128*128)-1)*4=FFFC
cnt.msb = &HFF
cnt.lsb = &HFC
rt& = TdcSendFunc(ud, func)
If rt& <> 0 Then
TdcPrepare = -1
Exit Function
End If
Point_Address = Chr(adr.msb) & Chr(adr.lsb)
ibwrt ud, Point_Address, 2
TdcPrepare = -1
Exit Function
End If
Point_Count = Chr(cnt.msb) & Chr(cnt.lsb)
ibwrt ud, Point_Count, 2
TdcPrepare = -1
Exit Function
End If
End Function
Dim rt&
DoEvents
If rt& <> 0 Then
TdcFunc = rt&
Exit Function
End If
rt& = 0
rt& = WrtInreg()
If rt& <> 0 Then
TdcFunc = rt&
Exit Function
End If
rt& = 0
rt& = ReadInreg
If rt& <> 0 Then
TdcFunc = rt&
Exit Function
End If
End Function
Hope any of you can give your opinion(s).
Thank you.
Variable IX,IY
Variable DataImage
// *** I see no reason to make these global
String PSDbuffer
// *** You have never assigned any value to UnitDescriptor.
tdcprepare(UdPSD, cmd) // *******
// *** Right - Igor is zero-based, like C
for (IX=0;IX<128;IX+=1)
for (IY=0;IY<128;IY+=1)
PSDbuffer = S_value
// *** This makes no sense to me
// *** You probably want something like:
// rawdata[IX][IY] = ...
At this point I conclude that you need to step back and read about Igor programming as there are too many mistakes and misconceptions to correct in this forum.
I recommend that read the following chapters of the Igor manual:
IV-1 - Working With Commands
IV-2 Programming Overview
IV-3 User-Defined Functions
May 11, 2011 at 11:53 am - Permalink
Thank you for reply my post.
The value for Unit Descriptor will be assigned when i use ibdev where i not include it in this post.
Did i need to put some value for cmd to initialized the cmd?
May 11, 2011 at 09:05 pm - Permalink
May 12, 2011 at 06:20 am - Permalink
You are passing cmd as a parameter from tdcDmaRead to tdcPrepare. In tdcDmaPrepare, you have this:
If you know that cmd should be 0x05 then there is no need to pass it as a parameter into tdcPrepare.
May 12, 2011 at 08:47 am - Permalink
jjweimer..yes it is better for me start from zero. I just use the VB program as my reference because I need to write IP program similar like the VB program..hehe
May 12, 2011 at 10:28 am - Permalink
